Adding 4 channels to a 2 channel input on HT amp
Old 1st May 2013, 10:58 PM   #11
philj is offline philj  United Kingdom
Basically yeah the 550 is the better amp, but doesn't have the 5.1 rca input. The 500d only has this input, so I need to remove that section and fit it to the 550 if its possible without having to enter software and rework that?
Old 1st May 2013, 11:49 PM   #12
jjrenman is offline jjrenman  United States
You would need the schematic, probably have to cut the proper circuit traces, add a six pole double throw switch or relays as well as adding or commandeering RCA's on the back of the 550. IOW a lot of work.
The only solution I can think of is to hook up the sound card to the 5.1 inputs on the 500. Hook up everything else to the 550 and then use a speaker level A/B amp selector. Something like using three Niles ABA-1D.
Old 30th October 2013, 03:14 AM   #14
Finally picked up the 550 amp. Quite eager to get this sorted if it is possible.
Anyone have any ideas? Or anyone in the UK who could do this for me?
Adding 4 channels to a 2 channel input on HT ampHide this!Advertise here!
Arjen´s TA2020 board: 1 channel into amp 2 channels on spekaers - WHY ? TheDealer Class D 12 19th August 2010 03:17 PM
Lowest frequencies found in HT channels krips Multi-Way 13 10th August 2009 03:25 AM
Adding Pass through input on my pre-amp RollE2k Parts 3 27th June 2008 04:47 PM
Adding center and rear channels nebelk Multi-Way 2 13th March 2008 07:05 AM
amp setup...4 channels on a 2 channel amp?! d1353lp0w3r Solid State 5 5th March 2008 05:59 PM
