Reed Switch Audio Attenuator
Old 11th December 2013, 04:30 AM   #41
Monte McGuire is offline Monte McGuire
My point was that they are not able to reliably close or open on a zero crossing of a waveform, so that the switch produces fewer or smaller clicks. This is sometimes done with CMOS switches.
What's even better to do with a CMOS switch is to do a soft switch, essentially ramping the switch open or closed, which can be done regardless of a zero crossing, and is far more effective at preventing clicks. It's like a crossfade edit rather than a straight cut.
Old 11th December 2013, 07:58 AM   #42
Bonsai is offline Bonsai  Europe
Did some one on the forum not plot distortion of a small signal through a reed relay and find it was higher than would be liked due to the reed sitting inside a strong magnetic field?
Old 11th December 2013, 06:13 PM   #43
I would nike to see that - I have wondered myself.
If that effect exists, it would not be from the static magnetic field, but by the signal current induced B field that also travels in the magnetically nonlinear reeds. While the reeds are ferromagnetic and signal passes through them, it's not clear that the potential nonlinearities are large enough to matter. Still, at speaker levels, it seems plausible.
Note that some conventional relay designs also pass signals through magnetic materials that compose the armature. It's not required, as it is in a reed relay, but it is possible depending upon the armature design.
Reed Switch Audio AttenuatorHide this!Advertise here!
Rotary switch for attenuator Alex M Parts 3 28th October 2011 09:35 PM
Are Coto 9007 reed relays ok for audio ? 00940 Parts 1 6th November 2008 06:43 AM
please reed if you know about audio kits!! subaru16162 Everything Else 2 7th September 2008 09:13 PM
Switch for stepped attenuator jnb Parts 0 4th October 2007 02:02 PM
Alps switch for stepped attenuator rebojorge Parts 3 12th January 2006 10:58 PM
