Reed Switch Audio Attenuator
Old 29th April 2013, 01:22 AM   #11
dheming is offline dheming  United States
dheming's Avatar
Originally Posted by soldersplash View Post
FYI - You don't need 36 relays for a 36 position attenuator. It is possible to make 127 step using 7 relays. Arranged as 1/2dB per step gives a practical 0dB to -63dB attenuator. Think binary...
Sent from my Nexus 7 using Tapatalk HD
Are you referring to the R-2R resistor ladder topology? They do indeed save on relays, but they also have widely varying impedance. There's also quite a few components in the signal path at times. Plus they need a binary counter to operate the relays which means a micro-controller of some sort.
None of the above traits are desirable to me. My goal with this project is to build a true ladder attenuator with passive operation. If there are any tricks to doing that using less switches I'm open to input.
Old 29th April 2013, 02:43 AM   #12
Bonsai is offline Bonsai  Europe
Non that I know of that will not end up with more than 1 set of contacts in he signal path.
Old 29th April 2013, 11:27 AM   #13
soldersplash is offline soldersplash  United Kingdom
Not necessarily R-2R but that kind of thing. Input resistance can be fixed vs. level setting. Output resistance varies still. But that will with you project as is, I think?
Yes, more components in path, it is true. For me that just meant finding sealed signal relays and high quality res. Binary counter, however, does not necessitate using a microcontroller.
I have no tricks for less switches and maintaining constant input resistance. Soz.
All the best with your project. I'm not on a mission to dissuade you. Hopefully my input will be useful/interesting/thought provoking for others visiting this thread.
Old 29th April 2013, 12:58 PM   #14
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by cliffforrest View Post
But they will be along soon to tell you how magnetics screw up
Not so much the magnetics, but the required lumped mass, and the cost.
Contact force of Reed switches is rather low, and they're prone to vibration.
So the attenuator has to be a bit bulky, which comes as a gratuity by using a stepper motor, the natural choice for accurate switching.
An Astrosyn type-14 mini stepper motor, as used by Weiss, easily adds $60 to the total cost (which is cheap, compared to what e.g. an Airpax stepper motor used to cost)
A Hamlin MDSR-4 reed switch now does a few dimes each, but before 2k they cost two times as much, >100 wholesale, without counting inflation.
(made a stepped attenuator similar to Weiss' in the late '80s, had to resort to the cheapest ones available, MDRR-4, still ~$60 just for the Reeds)
Very nice ones to look for is the Hamlin MDC series, mercury wetted.
An MDC-3 e.g. was over $5 each at 100 minimum in the early '90s, NOS ones now sometimes $50 for hundred.
(downside is the diameter, 0.1", requires an H33 magnet)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 29th April 2013, 01:16 PM   #15
DF96 is offline DF96  England
My concern about reed switches is their small contact force, and lack of wiping action. Being sealed in an inert atmosphere will help, of course, but if contacts can be a problem for audio then I would have thought that reed switches would be particularly bad. I guess mercury wetting will help, though.
Old 29th April 2013, 01:24 PM   #16
R.I.P.
I would expect that reed switches do have a wiping action.
regards Andrew T.
Old 29th April 2013, 01:44 PM   #17
Makes one wonder how long it will take for someone to think up a 48-60 piano key rotary attenuator with 25-cent mercury tilt switches.
Old 30th April 2013, 03:03 AM   #18
greenKnight is offline greenKnight  Australia
What should be the ideal step size 1dB, 2dB ????
Old 30th April 2013, 03:06 AM   #19
Also optimising magnet size to angle increment so one relay closes as the next one opens will be difficult.
Old 30th April 2013, 10:21 AM   #20
When I built a stepped attenuator I rationalised that I wanted a 'smooth' changing of level. The just noticeable difference in level is about half a dB so that's what I went for.
Reed Switch Audio AttenuatorHide this!Advertise here!
Rotary switch for attenuator Alex M Parts 3 28th October 2011 09:35 PM
Are Coto 9007 reed relays ok for audio ? 00940 Parts 1 6th November 2008 06:43 AM
please reed if you know about audio kits!! subaru16162 Everything Else 2 7th September 2008 09:13 PM
Switch for stepped attenuator jnb Parts 0 4th October 2007 02:02 PM
Alps switch for stepped attenuator rebojorge Parts 3 12th January 2006 10:58 PM
