PGA2310 - PGA2311 - CS3310: version without OPAMP for outdoor OPAmp connection wanted - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th April 2013, 11:19 AM   #1
tiefbassuebertr's Avatar
Default PGA2310 - PGA2311 - CS3310: version without OPAMP for outdoor OPAmp connection wanted
The IC type from the headline have two disadvantages for me:
1) The quality standart of the internal OP-Amp is unknown - not very high however
2) the variable resistor for the volume control is located in the NFB. This means, that the THD character is dependend of the level position resp. of the individual adjusted gain factor (particularly by freqencies above 10 KHz).
Therefore for me the question rises up, whether there are other versions, both at whole passive for the analoge signal pad so as with additional pins for use of various external operational amplifiers like AD797, LME49710 etc.
Thanks for advices.
Old 27th April 2013, 09:58 AM   #2
How about this one by Analog?
http://www.analog.com/en/digital-to-...s/product.html
1024 taps and all three terminals exposed
Old 27th April 2013, 09:54 PM   #3
sonnya is offline sonnya  Denmark
sonnya's Avatar
You can go 2 ways.
Davidsrsb solution. Which is analog devices and well documented datasheet
Or discrete R2R with todays standard of analog switches!
Old 28th April 2013, 05:04 AM   #4
Default as requested
MAS6116 - Stereo Digital Volume Control IC - Micro Analog Systems Oy
Old 3rd May 2013, 10:32 AM   #5
maxw is offline maxw  United Kingdom
maxw's Avatar
Any example of this?
Old 3rd May 2013, 02:29 PM   #6
BV is offline BV  Slovakia
DAC8043 (or similar) in multiplying mode (see datasheet) with quality OA, eg. OPA1642, OPA1612..Results are very good (example in attachment), but uP is a must. It is far better than PGA, MAS, CS or similar..
Old 3rd May 2013, 05:20 PM   #7
maxw's Avatar
What do you mean by "uP"? Do you have a schematic?
Is this the same implementation as these two?
Ultra high precision digital control attenuator
Audio electronic potenciometer
I want to make one!
Old 4th May 2013, 05:06 AM   #8
uP-microprocesor interfacing, schematic fig. 3 in datasheet. Vref is signal input.
http://www.ti.com/general/docs/lit/g...3&fileType=pdf
Old 7th May 2013, 10:51 AM   #9
interesting advices - thank you very much therefore.
An other question in this case is for me of interest. Which OP-Amp type corresponds to the integrated version at best?
The NE5532, OPA2604 or OPA2132?
Because there is no circuit diagram in the datasheet of PGA2310/2311, this is hard to say for me. Who know this ? The most interesting fact is the topology and the idle current of the output stage.
Maybe anybody can ask by TI this.
Thanks again.
Old 7th May 2013, 11:29 AM   #10
Today I would use e.g. OPA1611(or 1612-dual) or Jfet version OPA1641 (1642). There are no information about OA used in PGA, nor output idle current, but quiescent current for whole analogue section is about 10mA (both channels). I used PGA2310, but it was for me not satisfying..Try to find some information about THD(+N) vs.freq at gains other than 0dB, and input levels about 1V RMS, this is most used regime.
Which is the best sounding to your ears? CS3310,PGA2310 or PGA2311 henkel Parts 6 27th April 2013 12:49 PM
PGA2310 / CS3310 differential use ? blu_line Solid State 5 23rd December 2010 09:46 PM
pga2310/pga2311 source ygm Parts 6 17th May 2006 01:52 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Quick PGA2310/PGA2311 question. JoeBob Digital Source 3 26th August 2004 07:55 AM
Copyright 1999-2017 diyAudio
