IC's get hammered - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 29th April 2013, 04:12 PM   #101
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Originally Posted by jackinnj View Post
The "numbers" from the 3 tests in LA4 were derived in almost the same manner as those WJ wrote up in 1995 -- and as we now know they don't relate well to the subjective experience. I applied the Didymus test! (This is how Reinhart-Rogoff got debunked if you're up on your recent economics). But just because the correlation coefficients aren't high doesn't mean that Walt's design isn't the best sounding.
It's been pointed out to me (via Jan) that there may be another test which would relate to the ordinal scores. I did some simulation and it looks promising indeed!
In the interim, here's a description of the DUT:
What are the specific advantages of this regulator over say an LM317 or an LM723? Thanks.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 29th April 2013, 05:02 PM   #102
scott wurcer's Avatar
Originally Posted by manso View Post
There are no plate capacitors inside IC opamps., Except for thin films, caps are formed through the working of active parts such as mosfets and Jfets and Bjts. These parts are not quite as high performing as plate capacitors.
This is wrong, Google for MOMCAP (metal on metal) they can be quite good in fact there have been some sample and holds using them. They have their own layers of oxide and have nothing to do with the active devices (except for a shared layer or two when that works out).
You are laboring under the influence of Burson Audio's nonsense.
From a simple spice simulation you could easily observe the effects on phase margin and stability and distortion. For that youd need the full schematics and not just the simplified version on the datasheet.
None of note, especially distortion, please read Samual Groner's measurements. The Burson op-amp are only fair on many specs nothing any number of IC's couldn't easily better. Disclaimer - IMHO of course.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 29th April 2013, 06:27 PM   #103
jackinnj's Avatar
The Burson is a variant of the POOGE 5.51 -- note the differences:
Old 30th April 2013, 12:39 AM   #104
There is something wrong with the first regulator schematic. R4 in series with R5 makes no sense at all
Old 30th April 2013, 01:17 AM   #105
godfrey is offline godfrey  South Africa
Maybe the 1 Ohm resistor is just used as a jumper to help with PCB layout.
Old 30th April 2013, 01:22 AM   #106
Bonsai's Avatar
jackinnj, so the original circuit was the Buson, and the one directly above is the Pooge 5.51?
bonsai
Old 30th April 2013, 03:23 AM   #107
jackinnj's Avatar
I use a 1mA current source across the 1 ohm resistor to generate a 1mV perturbation signal.
TA2022 IC's Available HarryK Swap Meet 12 14th April 2008 08:15 AM
IC's vs Discretes Bonsai Solid State 9 19th September 2007 05:41 PM
Need IR2010s IC's maxzimum Class D 0 21st March 2007 09:54 AM
IC's for 2.1CH O/P bimbla Chip Amps 8 28th November 2005 11:54 PM
Copyright 1999-2017 diyAudio
