Line level mixing
Line level mixing
Old 14th May 2013, 02:22 AM   #21
rochest126 is offline rochest126  China
I upload my circuit diagram,can it is appeared?
Old 14th May 2013, 08:28 AM   #22
Mooly's Avatar
Line level mixing
Not appeared
Follow the instructions. Click "Go Advanced" and then "Manage Attachments".
Old 14th May 2013, 08:29 AM   #23
this is circuit picture.I means is when mute control switch to left,Q1 can turn-on slowly.And ,the signal on LineInp1 fade out.
Old 14th May 2013, 08:31 AM   #24
Originally Posted by Mooly View Post
Not appeared
Thank you! There are two Submit Reply button in reply page,I must to press below one.
Old 14th May 2013, 08:33 AM   #25
Mooly's Avatar
Line level mixing
Like this.
Old 14th May 2013, 08:40 AM   #26
Like this.
Thank you!
Old 14th May 2013, 08:43 AM   #27
Mooly's Avatar
Line level mixing
Your welcome
Old 14th May 2013, 08:47 AM   #28
Mooly's Avatar
Line level mixing
I'm not so sure the transistor would fade the signal as you want. It would tend to conduct fairly quickly as the base-emitter junction come into conduction probably introducing a lot of audible distortion in the transition period. Even FET's do that to some extent.
C5 and C7 are far to big. If you need them at all then somewhere around 10 to 47pf is suitable.
Edit... and C6
Old 14th May 2013, 10:06 AM   #29
godfrey is offline godfrey  South Africa
When the mute control is switched to the right, it short circuits the 10uF capacitor. The high current can cause a small arc in the switch. After many switchings, the switch contacts may be damaged.
It may be better to move the 10K resistor like this:
Old 14th May 2013, 10:15 AM   #30
Yes. An LDR (light dependent resistor) would be better for fading.
Line level mixingHide this!Advertise here!
Are piezo elements line-level or instrument-level signals? JGAN Instruments and Amps 27 17th April 2012 01:38 PM
(minimal) speaker level vs. line level high pass filter noviygera Analog Line Level 1 15th October 2011 09:43 AM
trouble matching line level to guitar amp input level...any help? mondogenerator Instruments and Amps 5 19th December 2009 10:00 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
