Line level mixing - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st April 2013, 04:34 PM   #11
Chris Hornbeck's Avatar
Originally Posted by DF96 View Post
If you want something other than the average of the two channels, scaled by some constant, then you need to do something far more sophisticated.
Doh! You're right - there's no simple resistive Y that doesn't give a 3dB boost to signals common to both channels (over the 3dB summing of speakers in rooms). Thanks much for the lesson - I've been drifting along with an old saw from the Klipsch derived center channel days that's never been true.
It must have come from analogy to stereo panpotting practice, where a source panned center is reduced 3dB to each channel compared to its level panned fully left or right. From speakers this adds as not correlated, and all's well. But simple resistive mixers (apparently, now that you've made it clear) add to 6dB, 3dB hot. Simple panpots can mix correctly, but simple resistive Y's can't undo it. Very interesting.
Thanks, as always,
Chris
Old 21st April 2013, 05:14 PM   #12
nigelwright7557's Avatar
I just short the 2 channels together and it works fine for me.
Not ideal but you cant get less components than zero !
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 22nd April 2013, 11:58 AM   #13
ODougbo is offline ODougbo  United States
FYI: EDCOR - S2M Series
Old 8th May 2013, 04:48 PM   #14
Ended up taking my own advice again, ordered some of the S2M combiners today.
btw, Edcor is a tube amplifier transformer source (I may be the last to know).
Old 10th May 2013, 01:41 AM   #15
I want to realise fade out effect in one channel of mixer,is it works?
Old 10th May 2013, 03:50 AM   #16
Pano is offline Pano  United States
Pano's Avatar
You put a link to a MSN password protected page. Is that what you wanted to do?
The link has been removed.
Old 10th May 2013, 04:04 AM   #17
sorry,i try other storage
Old 10th May 2013, 04:31 AM   #18
Old 10th May 2013, 07:13 AM   #19
Mooly's Avatar
Try attaching your picture directly like this,
To add a photo, files or non standard files.
First click "go advanced" in the box below the "quick reply" message box. Doesn't matter if you decide half way through a message to do that, it carries it forward.
Then click "Manage attachements". Maximise the new Window so that you can see all the text.
Click browse in the first box at the top and find your picture. Repeat for any more pictures.
Click upload... a message appears "uploading"
When complete the files will show as being attached. Now click the small text that says "close this window"
The pictures should now be attached and when you submit your post they will appear.
Make sure your pics aren't too big, a couple of 100k is plenty, and many members object when they are massive and it alters the margins
It tells you in the attachments window what max sizes are allowed.
If you want to attach a file that has a non standard format for example excel, circuit simulation etc then try putting the files in a zipped folder and attaching that.
Old 11th May 2013, 01:28 AM   #20
Thank you!
Are piezo elements line-level or instrument-level signals? JGAN Instruments and Amps 27 17th April 2012 01:38 PM
(minimal) speaker level vs. line level high pass filter noviygera Analog Line Level 1 15th October 2011 09:43 AM
trouble matching line level to guitar amp input level...any help? mondogenerator Instruments and Amps 5 19th December 2009 10:00 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
Copyright 1999-2017 diyAudio
