Need an Active 2nd Order Low Shelf Filter aka Low Shelving Filter - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th April 2013, 11:51 PM   #11
elmura is offline elmura  Australia
I was after a low frequency cut. I have a HF shelf boost, and LF shelf boost. What I'm having trouble finding is an active LF shelf cut. Have you seen one?
Old 27th April 2013, 12:32 AM   #12
Michael Bean's Avatar
elmura,
I think you could adapt my tone control circuit (here: A usable tone control) to your needs, just scale the filter components to the desired frequency and pick a attenuation level, and you're there.
Mike
Old 28th April 2013, 03:13 AM   #13
Interesting work Michael. I've been playing around with it in Tina simplifying it to my requirements. It works great.
Questions:
1. Is this a biquad?
2. What do you adjust to alter corner frequency?
3. Is it possible to do the same thing with one opamp for bass shelf cut? ie. a simpler design?
Old 28th April 2013, 03:15 PM   #14
elmura,
If you take a look at the tech-pub by Dennis Bohn at Rane Corporation (here: http://rane.com/pdf/acceler.pdf), it should answer many of your questions, this circuit is based on that work. The original circuit utilized a dedicated opamp for each filter; by scaling the first filter's resistance/impedance level I was able to eliminate one opamp from the filter section.
1) No, it's not a biquad, it's a non-traditional type cascade of two first order filters that, because of the way thet're implimented here, will provide a steeper than normal slope while limiting phase shift.
2) If you read through the whole thread I started (here: A usable tone control), you probably noticed the original version had filters where the corner frequencies were easy to adjust. After evaluating the first circuit I still wasn't happy with the way it affected the mid-band frequencies. That's when I decided to try the accelerated slope type of filter, but in using those I gave up the easy frequency adjustment the original had.
To change the filter corner frequency, a simple mathematical scaling of the cap and/or resistor values works well, just be sure to scale both of the cascaded filters equally.
3) The circuit is already about as simple as it can be. It requires a summing inverter at the input, a summing inverter at the output, and what ever filter stage(s) in between to provide the transfer function desired, a typical topology for many graphic and parametric equalizer circuits.
As a final comment, the circuit is simple, easy to build and tweek, tolerant of less than ideal physical layout, and best of all when done right won't get in the way of the music.
Mike
Second order shelving filter Buriedcode Analog Line Level 1 18th April 2013 08:19 AM
Preamp mod with a low cut shelf filter johanwahlberg Analog Line Level 11 11th December 2012 04:18 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
1st order low-pass filter, which cap ? Thmartin Parts 4 17th November 2005 08:37 AM
1st attempt of 2nd order active lowpass filter failed, please advise SimontY Software Tools 111 15th February 2005 10:32 PM
Copyright 1999-2017 diyAudio
