Input Impedance Question
Old 28th January 2013, 01:34 PM   #11
Loren42 is offline Loren42  United States
Originally Posted by Mooly View Post
If your feeding this from a tube amp then you must be certain that not only is the tube amps output cap OK but also that it has a high value resistor to ground (even if its 10meg) on the output. If not and its floating then the cap could charge to some high voltage and this would zap the IC as soon as you connected.
Good point. I'll simply replace the cap with a new one just to be sure.
Old 28th January 2013, 01:48 PM   #12
Mooly's Avatar
If it needs it then yes
But it must be terminated on the output side to ground via a high value resistor (which it may already have). If it hasn't and you leave it floating, then the output will assume whatever voltage is on the other side of the cap (tube amp... could be 50v to ??? who knows) and that would instantly zap any solid state unit you attempted to connect it to.
Old 28th January 2013, 03:47 PM   #13
Here is the PAS 3 circuit. Not likely that there will be DC on the output since at least two caps would need to fail (double fault).
Old 28th January 2013, 04:10 PM   #14
R.I.P.
It is not for a capacitor failure.
That 510k , connected form 7 to 1, is the grounding resistor to prevent you blowing up the next stage.
Measure it to make sure it is still operational.
regards Andrew T.
Old 28th January 2013, 04:30 PM   #15
Ah! Thanks! I will do that.
Old 28th January 2013, 06:07 PM   #16
Mooly's Avatar
I saw this, and thought of you ,
Alittle disaster story
Old 28th January 2013, 06:13 PM   #17
Thanks. I needed that.
Old 28th January 2013, 06:16 PM   #18
Mooly's Avatar
Your welcome. Now check that 510K
Input Impedance QuestionHide this!Advertise here!
input transformer and impedance question milen007 Tubes / Valves 12 12th November 2014 12:50 PM
Question about preamp input impedance cumesoftware Solid State 3 15th July 2012 10:29 AM
input impedance of mosfet question? AudioGeek Solid State 2 9th November 2009 03:11 AM
Chipamp input impedance question EBM_dude Chip Amps 6 26th October 2009 04:52 PM
Amp input impedance question ? sam9 Solid State 9 21st April 2005 02:28 PM
