Parametric EQ based bass boost circuit
Old 26th January 2013, 09:03 PM   #11
Hengy is offline Hengy  Canada
Ok, So I was looking around the ESP site, and I came across the Baxandall tone control circuit. A few adjustments later, I came up with this. Simulates exactly what I want!
Next step is to build it.
rsavas,
I'll need to place an order from Digikey. They have the NE5534P. I'll get two, and compare them to my LME49740s I have. I like to think my ears are pretty good! (and my Audio Technica M50s, too!)
Hengy
Old 27th January 2013, 08:53 AM   #12
stratus46 is offline stratus46  United States
I'm not saying it won't work, just that it's not a true parametric equalizer. I get the impression you think I'm claiming Rod is 'lying'. People say all sorts of things that aren't true by misunderstanding. I use 'lying' when someone attempts to deceive but I don't think that of Rod at all. I use him a a reference on occasion. Or maybe I'm just too picky.
This may very well be all you need. You have reduced tuning range and no control of 'Q' - while it's operating. You CAN change the 'Q' with component changes but it's not easy to do it with a pot in this configuration. Again, this may be totally satisfactory as it is. Try it and if you need more control it's possible.
G
Old 27th January 2013, 12:02 PM   #13
rsavas is offline rsavas  Canada
The Popular Electronic article has this option to run from a single supply. It lifts the EQ ground to 1/2 Vcc & uses two of the OPA's to buffer this 1/2Vcc to create a virtual ground.
Old 27th January 2013, 12:34 PM   #14
Stratus46,
You misunderstood me! I in no way think Rod is lying. I thought that it would not work because of what I was trying to turn it into - something that I didn't fully understand. That's all. I have reward the ESP site from top to bottom many times, and consider Rod to pretty much be the authority!
I googled for a "bass boost" circuit before trying to adapt my own, but didn't find much.
The last circuit I posted does everything that I want. I think I started with something too complex with the parametric EQ.
Thanks for the help everyone.
Hengy
Old 27th January 2013, 12:45 PM   #15
Bass boost ckts, take a look at Linkwitz Lab - Loudspeaker Design
In particular, Active Filters, shelving low pass, if all you want is extended bass boost.
Parametric EQ based bass boost circuitHide this!Advertise here!
A bass-boost circuit for OB Roushon Multi-Way 40 5th October 2012 07:44 PM
LT/ parametric bass boost of vented enclosure muddasirwaheedmalik Subwoofers 3 6th December 2011 03:42 PM
Remove mid range boost EQ circuit? mr.duck Analog Line Level 4 19th June 2009 06:21 AM
Bass Boost Circuit metal Chip Amps 0 15th November 2005 08:29 PM
simple bass boost circuit deepanger Solid State 11 28th December 2002 01:37 PM
