Preamp has unwanted delay (and hum) - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd January 2013, 03:14 PM   #11
OK fair enough. Thanks for everyone's help with this.
Old 23rd January 2013, 05:49 PM   #12
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
In the resistor divider to bias the opamps input, use two r's shunted both with caps, this way you are creating a compensated voltage divider as used in oscilloscope proves. I used that configuration several times, and the secondary advantage is that the input is bypassed to both rails. Also, you can use one more OP to decouple voltage divider from ICs's input, but not too necessary in this case.
In the schema you posted, the cap is charging to reach exponentially the value of VCC/2, on time the minimum voltage to the opamps can work in class A, in this moment the audio is getting from the output. And, also, when shut down the circuit, this cap continues charged although the opapms are not, and this is very dangerous to the input stage of the opamps.
Best regards.
Good luck!.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
help: preamp hum monsieur2 Solid State 9 15th May 2009 03:28 PM
The Look of Preamp Hum tgorham3 Tubes / Valves 1 22nd March 2008 04:22 PM
Preamp output delay derekyu Tubes / Valves 4 28th June 2006 05:49 PM
Preamp hum. mschwilson Solid State 1 2nd April 2006 07:07 PM
Copyright 1999-2017 diyAudio
