Digitally controlled pot distortion?
Old 13th January 2013, 01:58 PM   #1
Tenson is offline Tenson  United Kingdom
Default Digitally controlled pot distortion?
I need to make a volume control for a stereo balanced signal. Since 4-gang pots are difficult to get, I have been considering using a digital potentiometer IC.
There are lots about; Wolfson WM8816, Maxim DS1844, National LM1972 etc..
My question is whether these can really be thought of as passive resistive elements or do they introduce distortion of their own (say though transistor switching of the resistor ladder)? The WM1816 datasheet gives a THD+N figure of -100dB but maybe this is really down to the op-amp buffer?
Old 13th January 2013, 03:19 PM   #2
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
I built a digital mixer using Microchip digital pots and it sounded fine.
So long as you keep the voltages between 0 volts and 5 volts then there wont be much distortion. I found I had to keep inputs and output biased around 2v5 or I got terrible distortion.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 13th January 2013, 03:29 PM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The switches are the most non-linear part in my understanding - CMOS switches have a non-linear voltage vs resistance curve. This should mean the distortion reduces as the signal level goes down. Whilst the output opamp won't show much THD, chances are the audio performance is limited by low level IMD.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th January 2013, 04:37 PM   #4
counter culture is offline counter culture  United States
You can get passive-type digipots, but they tend to have quite high distortion.
You're better to go with the chips intended as volume controls such as the Wolfson you named or the TI PGA23xx series or Cirrus equivalent. I think the TI chips actually have the best paper performance, but these things are not set in stone.
The volume controls are not purely passive, they generally offer gain as well as cut, this is provided by internal opamps. This is not a good reason to reject them as the levels of distortion they achieve are almost certainly sub-audible. Some are only intended to work with maximum 5V levels, but some will work with +/-15V.
A device that shows low THD is very unlikely to have high IMD.
Chances are that the IMD is insignificant.
Old 14th January 2013, 10:22 AM   #5
Thanks for the replies chaps. Looks like the LM1972 is the best from the spec sheet. However I know nothing about programming micro-controllers! I think that is something to spend a bit of time reading up on
On the other hand, if I got a order of quad linear pots (Vishay P9) would people be interested in buying some off me? Obviously linear pots can be make log with the addition of a law faking resistor. I guess I'd go for either 1K or 5K.
Old 16th January 2013, 07:35 AM   #6
qusp is offline qusp  Australia
qusp's Avatar
the Ti PGA4311 A GRADE type. has better numbers 120db DNR and 0.0002% THD+N
its also 4 'deck'
Old 16th January 2013, 07:47 AM   #7
abraxalito's Avatar
That part has 10MHz CMOS opamps on-board so the THD+N figure is certainly not to be trusted as a FOM for audio SQ.
Old 16th January 2013, 08:43 AM   #8
qusp's Avatar
i'm not a fan either, but I dont like any of them since they basically become the dominant factor of your analogue stage whether you like it or not. however the spec has been tested, I suggested it as spec seemed to be the metric under discussion and he needed a 4 channel part
Digitally controlled pot distortion?Hide this!Advertise here!
Low distortion & noise digitally controlled volume chip abraxalito Analog Line Level 6 13th August 2011 01:14 AM
0 to 100V digitally controlled supply jegonz Power Supplies 1 17th September 2010 03:21 PM
A good digitally controlled resistor pot AKSA Solid State 62 11th June 2008 12:40 PM
Digitally controlled LED panel help... needtubes Everything Else 0 28th June 2007 01:53 AM
Digitally controlled Baxandall? BoGoMiPz Solid State 21 19th February 2004 01:41 PM
