| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
How many boards for a three way 4th order crossover?
#22 |
at minimum 8 Buffers per audio-/stereo-channel. 2 for the Tweeter-HP, 2 for the Mid-HP, 2 for Mid-LP and 2 for woofer-LP. Since tweeter, Mid and woofer channels are connected in parallel, add 1 Buffer as Input-Buffer/Isolator. Then add maybe 2 or 3 more as output buffers if potis are wished for to individually set each channels volume level. If aditional equalizing/filtering is needed add some more. jauu Calvin
http://calvins-audio-page.jimdo.com |
#23 |
Thanks Calvin for chipping in.
![]() Patrick
xen-audio.com |
#24 |
I think pots would be essential. So that's 12 per balanced channel, thankyou.
#25 |
Calvin
Thanks for the clarification that's were my understanding got me to, I needed reassurance I was on the correct path. Tony |
#26 |
I Have not given up with this, just very busy at work and will be until 1st Feb, thanks for everyones help and encouragement.
Tony |
| Joachim Gerhard Filter Buffer for ES9022 | EUVL | Group Buys | 578 | Yesterday 12:22 PM |
| Balanced buffers - analogue volume control | cbuzz99 | Analog Line Level | 3 | 31st May 2012 07:18 AM |
| Potential Group by for Balanced Input Buffers with Ingenius 1200 IC from THAT Corp. | Tiff_Needle | Group Buys | 24 | 16th November 2011 02:25 PM |
| ZDL thread by Joachim Gerhard | jamikl | Multi-Way | 14 | 21st July 2011 06:10 AM |
| Active crossover with Jfet buffers? | Fuling | Solid State | 17 | 30th September 2006 04:45 AM |
