5 band equalizer, need help!!
Old 4th January 2013, 10:45 AM   #11
Aniket is offline Aniket  India
Aniket's Avatar
I dropped that project and kept that board aside for a while, would check that later.
As i need the eq. urgently, i am constructing another circuit, as attached using TL074 opamps. I found the schematic on HiFiEngine, would update soon.
Hi, Gajanan, thanks a lot for the advice, as the chasis is grounded, no need to ground the potentiometers, hum is not present due to any grounding mistake,
maybe the schematic is wrong and need to rectify that.
As of now, I'm uploading both the schematics, advice is most welcome.
Aniket
Old 4th January 2013, 11:04 AM   #12
csom is offline csom
csom's Avatar
1. Can you try your earlier 5 band Equalizer circuit with a circuit simulator like LTSpice etc. so that you might get what's going wrong with your mod?
2. How about using a project board/bread board like the following instead of the vero board/perf board at first to test, you could save money I guess. Just a suggestion.
http://www.diyaudio.com/forums/attac...read-board.jpg
Warm regards, Som
Old 4th January 2013, 11:15 AM   #13
Aniket's Avatar
Hi Som,
Yes, i would LTSpice my earlier mod sometime later for sure. vero board are really cheap here in Delhi and Gurgaon, cost only 25 Rs. I have never used bread board, and may be the are expensive here. I am good at soldering i find it easy to construct on a vero board.
Aniket
Old 4th January 2013, 12:30 PM   #14
csom's Avatar
I am eager to know about your progress and the result with this ongoing 5 band Eq project.
Please do keep us informed about your "YAY!".
Wish you all the very best.
Thank you.
Warm regards, Som
Old 12th January 2013, 02:52 PM   #15
Aniket's Avatar
New eq. working great, nice control on each frequency band, no hum, hiss, dead quiet, crystal clear sound. Here are a few pics. I would also mention that I changed value of C10 to 0.01uF instead of 0.001uF as in the schematic for 13kHz frequency band, with 0.001uF there was no cut or boost, but working brilliant with 0.01uF.
Aniket
Old 12th January 2013, 02:55 PM   #16
csom's Avatar
Very nice! congrats!
Warm regards, Som
Old 6th June 2013, 01:49 PM   #17
csom's Avatar
Hi Aniket,
I want to make an equalizer using some left over TLO74s. But I found that some parts are illegible in your uploaded reference. Could you kindly post your modded, simplified and tested circuit so that I can follow it?
Eagerly awaiting your reply.
Thank you.
Warm regards, Som
Old 9th June 2013, 03:49 PM   #18
Aniket's Avatar
Hi csom,
please tell, how many bands you require??
the circuit which I am currently using is a 5 band eq. using all TL074's. and it's working great.
how many frequency bands you require, please elaborate your needs, i will help.
Aniket
Old 9th June 2013, 03:56 PM   #19
csom's Avatar
Hi Aniket
I need a 5 band eq to fix an old amp. So it would be great if you could give me a 5 band using TLO74 since I have some unused TLO74 chips with me.
Thank you so much
Warm regards, Som
Old 9th June 2013, 04:35 PM   #20
csom's Avatar
Kindly include the power supply section too. And If you have made a pcb for that please share at your convenience.
Thank you
Warm regards, Som
5 band equalizer, need help!!Hide this!Advertise here!
3 Band Equalizer for Amp JoshwaBurke Software Tools 3 3rd August 2012 02:23 PM
NEUMANN 3-band equalizer refference Analog Line Level 0 21st November 2009 12:58 AM
5 Band Graphic Equalizer NSLogan Chip Amps 2 17th June 2009 03:52 AM
quality 10 band Equalizer space2000 Solid State 5 26th May 2008 07:47 PM
need equation for 3 band baxandall equalizer prorms Solid State 8 14th December 2006 02:24 PM
Copyright ©1999-2017 diyAudio
