| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
I found this circuit which has a 200hz cut for the high and low pass filters, is it as simple as changing some capacitors from the shown values in the schematic to lower that down to 100Hz or 80Hz cut? Subwoofer filter - Electronic Circuits and Diagram-Electronics Projects and Design
| power suply for Pre & Phono Use tube 6BM8 | dia thien thai | Tubes / Valves | 5 | 23rd November 2011 04:17 PM |
| FS: 1626 Tube Amp, Van Alstine pre, tubes, crossover. | xecluded | Swap Meet | 1 | 30th April 2009 07:27 AM |
| Seperate power supply for pre-amp section in integrated amp? | KevinLee | Solid State | 8 | 2nd February 2008 10:20 PM |
| WIll an X-PSU v1 power an SI T-amp &/or TC754 pre-amp? | gnostic19 | Class D | 7 | 3rd August 2007 01:26 AM |
| Using power supply to power pre-amp? | preiter | Chip Amps | 4 | 11th May 2006 12:52 PM |
