Preamp-Buffers - simple idea - Page 21 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th July 2013, 07:02 PM   #201
Joachim Gerhard's Avatar
I buy the LSK parts at the German distributor. So far no problem to get them.
Old 15th July 2013, 05:49 PM   #202
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Here is an even easier, simple circuit that has only 2 jFET's and 3 resistors:
Using +22 and -22 vdc supplies, 2H and 3h and beyond are all <-120dB. R4 nulls the THD to almost nothing without cascoding.
Thx-RNMarsh
Old 16th July 2013, 10:14 AM   #203
Calvin is offline Calvin  Germany
Calvin's Avatar
I wouldn´t use fixed resistors from the start, but either of two options.
The optimum degree of current source modulation is load dependant.
The poti-setting differs between low-impedance/high load-current loads and high-impedance/low load-current loads and should be set after the lowest load impedance one expects and highest current swing symmetry.
The first option beeing to solder pots permanently.
Bürklin lists a decent range of 3mm², 4mm² SMD multiturn pots from Bourns and BI-Tec as does Digikey with several vendors up to Vishays MetalFoil.
The second using pots provisionally to evaluate the right values and replace them with fixed value resistors permanently.
jauu
Calvin
Old 16th July 2013, 01:08 PM   #204
FdW is offline FdW  Netherlands
FdW's Avatar
Thx-RNMarsh
Attachment 360321
And now the ATL handed me a DC coupled version
Old 16th July 2013, 06:48 PM   #205
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Frans
I believe the idea was to use a Nfet and a Pfet to cope with non linearities... Now the ATL adds another single fet as part of the servo.... does it comply ?
RC
Old 16th July 2013, 06:58 PM   #206
The opamp as a buffer alone will have less distortion then this one, but....
does it sound as magical ?
Old 16th July 2013, 07:39 PM   #207
FdW's Avatar
The simulator gives the same results for both circuits, except for the output offset, that is nearly zero with the servo. The added fet just functions as a resistor.
Old 17th July 2013, 06:17 AM   #208
Calvin,
thanks for sharing your thoughts. I'll simply integrate both to the board Should be easily possible to add some additional pads for fixed resistors without too much additional board space.
BTW (@all): would you prefer 1ch or 2ch boards?
regards, Daniel
Old 17th July 2013, 11:28 AM   #209
Calvin's Avatar
single channel, 4-layer double-sided, all SMD, with PCB-board connectors to a motherboard, 104µm copper silver coated, Teflon, black solder resist and white silkscreen with my avatar as logo would make me happy ;-)
jauu
Calvin
Old 17th July 2013, 12:24 PM   #210
sounds good what about embedded self-powering PSU (energy harvesting), wifi remote control,...
phono preamp 'input buffers'. fap Analogue Source 43 9th December 2011 08:46 PM
eBay&etc cheap tube buffers/preamp .. anything good? pedromreis Tubes / Valves 9 4th November 2011 03:51 PM
Preamp Input Selector & Buffers Devil_H@ck Chip Amps 9 2nd May 2004 10:29 AM
A simple chassis idea Peter Daniel Everything Else 34 5th December 2002 12:57 AM
Preamp design question -- where to put buffers? gretzteam Solid State 6 1st March 2002 04:36 AM
Copyright ©1999-2017 diyAudio
