Preamp-Buffers - simple idea
Old 27th March 2013, 03:43 AM   #11
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Originally Posted by georgehifi View Post
Hi Calvin, here is one that John Curl seemed to like and the DC offset trim works a treat. If you could sim it that would be nice. I'm using it and it sounds better than A in your first post which I had before.
Cheers George
Interesting. I wonder how it would compare to C and D.
EDIT: btw IMHO A sounds better than B
Stefano
Old 27th March 2013, 03:49 AM   #12
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That is a driven cascode. It can be improved much and i have shown elsewhere.
Old 27th March 2013, 03:50 AM   #13
My comment is for post 10.
Old 27th March 2013, 03:51 AM   #14
In what way does it sound better ?
Old 27th March 2013, 04:00 AM   #15
Stefanoo's Avatar
Still referring to post 10? I would be curious to know that too
Stefano
Old 27th March 2013, 06:06 AM   #16
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
It seemed to have better more solid drive and dynamics into my Lightspeed Attenuator which is around 7k input, and the poweramp which is around 50k so it was seeing a total load of around 6k I don't know if this was the reason though.
Or maybe it's the fact that it can be dc coupled with the 250ohm trimpot which it is now trimed to .1mV offset, and steady once over the inital switch on bump of around .500mV but this quickly settles.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 27th March 2013, 10:37 AM   #17
gk7 is offline gk7
What to use as replacement for the SST4391 (out of production) ?
Old 27th March 2013, 11:36 AM   #18
dadod is offline dadod  Croatia
dadod's Avatar
Cheers George
You can improve this to bootstrap cascode.
File Type: jpg fetbuffer%202%20+%20dc%20offset%20adjust.jpg (43.2 KB, 2093 views)
Old 27th March 2013, 12:04 PM   #19
gk7 is offline gk7
... here is one that John Curl seemed to like ...
Im not aware of any John Curl schematic where this buffer was used.
(Its from a chinese ebay seller if Im not mistaken.)
What John did use, is a similar configuration without cascode for the
output of the JC-2 (ML-1) phono stage. Its within the feedback loop
in this phono stage, though.
Old 27th March 2013, 12:09 PM   #20
manso is offline manso
Arent the Jfets in the original post 10 already bootstrapped, the only diffrence is that you are removing the 22 ohm resistors.
Preamp-Buffers - simple ideaHide this!Advertise here!
phono preamp 'input buffers'. fap Analogue Source 43 9th December 2011 08:46 PM
eBay&etc cheap tube buffers/preamp .. anything good? pedromreis Tubes / Valves 9 4th November 2011 03:51 PM
Preamp Input Selector & Buffers Devil_H@ck Chip Amps 9 2nd May 2004 10:29 AM
A simple chassis idea Peter Daniel Everything Else 34 5th December 2002 12:57 AM
Preamp design question -- where to put buffers? gretzteam Solid State 6 1st March 2002 04:36 AM
