VU meter arduino project help
Old 17th December 2012, 04:43 PM   #1
plasmaninjaa is offline plasmaninjaa
Default VU meter arduino project help
Hello, I have been trying to finish the VU meter project found in the 30 arduino projects for the evil genius book.
I have followed it to the best of my abilities, but for some reason it is not working.
The VU meter only lights up when I blow hard into the microphone or play loud music from my phone directly overtop, and even then it doesnt seem to be very in sync with the music. Its as if it refreshes only every half second.
When there is no noise at all, the VU meter sits at the first bar, and even stays there when I shout from a distance.
-here is the project from the book: http://i50.tinypic.com/23k3gy1.png
- here is the code copied from the book:
int ledPins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
int switchPin = 2;
int soundPin = 0;
boolean showPeak = false;
int peakValue = 0;
void setup()
for (int i = 0; i < 10; i++)
pinMode(ledPins[i], OUTPUT);
pinMode(switchPin, INPUT);
void loop()
if (digitalRead(switchPin))
showPeak = ! showPeak;
peakValue = 0;
delay(200); // debounce switch
int value = analogRead(soundPin);
int topLED = map(value, 0, 1023, 0, 11) - 1;
if (topLED > peakValue)
peakValue = topLED;
digitalWrite(ledPins[i], (i <= topLED || (showPeak && i == peakValue)));
here is a overhead view of my circuit: http://i45.tinypic.com/2zfqu5s.jpg
side view: http://i49.tinypic.com/15ews35.jpg
computer screen: http://i46.tinypic.com/wukuf8.jpg
I printed out the values coming from the input of the mic, they hover around 140-150 no matter what, even if I tap the microphone. they only change when I blow into the mic or play loud music directly on top of it. And even then, they dont really go with the music... sometimes they go really low.
So I'm not sure what I did wrong, I followed the instructions as best as I could and I'm pretty sure I did everything right.
The transistor is a BC548-4 30v 100ma transistor, the cap is 10nf film rdl...
does anyone know where I went wrong?
Thanks!
Old 22nd December 2012, 02:37 AM   #2
linuxworks is offline linuxworks  United States
linuxworks's Avatar
test your a/d circuit with a simulator. a pot with one end to vcc, one end to gnd and wiper to the a/d arduino input pin. run your 'print' debug program and vary the pot from end to end. do you read values? are they stable?
also, you should multiread and average to get better readings.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 22nd December 2012, 04:32 AM   #3
tauro0221 is offline tauro0221  United States
Check the voltage coming from the transistor to the input port #0 in the micro. Normally the input range for the A/D it is 0 to 5 volts and the micro will convert it to 0 to 1023 counts. So each count would be 5 / 1023 = .0049mv.
Old 22nd December 2012, 02:03 PM   #4
it turns out the diode was backwards. very strange since i thought the black line was the cathode on most diodes
VU meter arduino project helpHide this!Advertise here!
another DIY LCF meter (arduino based) linuxworks Equipment & Tools 2 2nd December 2011 12:18 PM
vu meter surfstu Tubes / Valves 14 24th March 2009 09:03 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
VU Meter Deltat Everything Else 5 19th January 2005 08:59 PM
VU meter nbcd Solid State 5 16th November 2003 09:02 PM
