| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#71 |
similar mistake in post67.
Multiple grounding creating loops. |
#72 | |
I have not implemented that after I found a lot of hum appeared due to the "contaminated ground" in that connection, as you have very aptly pointed out. I am now using a common PSU for the Equalizer, Preamp and the X over and another for the Power Amplifier section which is now isolated and placed on a wooden board for the time being. And interestingly, there is no hum or any kind of noise even after a continuous running of some 12 hours. I am just trusting my ears as I have no oscilloscope or other tools to identify the noise figure if any. So I want to continue with this arrangement until A problem occurs. But still I want to know what, according to you, is the ideal Power supply arrangement in this case? Do you recommend individual transformer for each section? Thank you so much again for your valuable words.
Warm regards, Som |
#73 |
Main Audio Ground (MAG).
ONE and only one MAG |
#74 | |
Do you expect that some Members read both posts and would copy what you posted? Tell them what does NOT work is just as important as telling them what does work. TELL THEM !!!! |
#75 | |
Thank you Andrew.
Andrew, I definitely posted my working PSU connection at post #67 that worked nicely in my case. I asked this question to all earlier ( at post #63) whether it was possible or not. And since sometimes realtime conversation don't take place here, it took me some time to get a reply from Sudhir (who was the first to reply). Sudhir suggested that using single transformer is not a good idea. Meanwhile, before that, I, being impatient, gave it a try and found that as a bad solution and posted my working PSU arrangement at post #67. So I posted what WORKED for me, I think at post#67. And more, the circuit from that site contains a power supply onboard and as I said earlier, it is very well documented. So this personal question of mine is simply redundant to anyone unless one wants to bulild a single PSU for Eq, Preamp and X-over. And regarding my leaving the post there, I cannot edit my posts after 30 mins or so I guess. Yes, the project is finished and I have been listening to it and "loving it". Sorry for any confusion that occured on your part. Last but not the least, with due respect to your experience and wisdom, I would prefer a patient "Tell them!" instead of "TELL THEM!!!!" Thanks.
Warm regards, Som Last edited by csom; 27th December 2012 at 02:24 PM. |
#76 | |
Sorry, you did tell them. |
#77 |
No problem Sir
))It happens to all of us ![]() Anyway, thank you really for helpful suggestions and guidance, keep them coming, I need them
Warm regards, Som |
#78 |
Okay, here is the complete arrangement of my amp that is performing impeccably with only two transformers for me, in my case, since last 24 hours or so.
No hum, no hiss, no unwanted noise, very quiet as usual.
Warm regards, Som |
#79 |
Still lot of works, lol!
![]() Any DIY suggestion for the front plate ? Please feel free to suggest/guide me
Warm regards, Som |
#80 |
| Peamplifier and active crossover, working project | geminni | Solid State | 11 | 6th October 2010 05:52 PM |
| AnAnalogue active crossover for speaker project! | dogscanskate | Multi-Way | 16 | 31st December 2009 05:50 AM |
| 3 Way Active Crossover Design project | powagrip | Multi-Way | 13 | 23rd February 2005 08:06 PM |
| active crossover project | victordsouza | Multi-Way | 0 | 9th September 2003 04:17 PM |
