DIY 3 way active crossover: as Christmas Holiday Project - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th December 2012, 09:49 AM   #11
csom's Avatar
Originally Posted by sudhir kumar View Post
I have made and used above said crossover. It has very good performance...compare it with esp project...It is almost same.All parts are easily available & every detail including pcb pattern is provided on site.
thanks.
sudhir
Thank you really so much Sudhir for your kind advice. I consider your this post as an encouragement.
Sometimes we face problem due to a slight inadvertent mistake in the PCB design posted on the internet . But your words really helped me to get rid of that concern.
Could you please tell me how you made the PCB ? I am a bit hesitant to use my old toner transfer method in this case as the board is large and fairly complex.
( Oh, I purchased 6 TLO74 Ics and sockets and some 1% metal resistors. And some other parts are already in my inventory. So wish me luck please )
Warm regards, Som
Old 17th December 2012, 10:47 AM   #13
csom's Avatar
Thank you so much Piersma for your reply.
I am using a two way setup from the ESP site. I definitely found an improvement using them over my passive network that I used earlier. No biased opinion here. So I decided to use a 3 way system mainly to learn, to experiment while DIY-ing is an added pleasure.
The links are really good. But unfortunately they have hardly any readymade PCB layout design to start with ( except the kit which is the best way to make a quick start). Perhaps I can design the layout myself but I am impatient right now
The last link has a very well thought out discussion on different aspects of using Xover as I can see.
So I sincerely do appreciate your post. Thank you again.
Warm regards, Som
Old 17th December 2012, 11:01 AM   #14
diyAudio Member RIP
Unfortunately standard L/R electrical crossovers are no short
cut to high quality loudspeaker design, they are too inflexible.
rgds, sreten.
Old 17th December 2012, 11:12 AM   #15
csom's Avatar
Thank you for your reply Sreten.
I completely agree.
That's why I am in search of a tested PCB layout as I am not so skilled.
Warm regards, Som
Old 17th December 2012, 11:17 AM   #16
pinkmouse's Avatar
Thread moved to appropriate area.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 17th December 2012, 11:26 AM   #17
csom's Avatar
Thank you pinkmouse.
I apologize as I failed to create the thread in the proper place
Warm regards, Som
Old 17th December 2012, 02:30 PM   #18
csom's Avatar
I talked to a PCB making company in my locality.
Hopefully I will get the PCB in a week or so.
I will keep everyone updated about my progress.
Thank you all .
Warm regards, Som
Old 17th December 2012, 03:36 PM   #19
diyAudio Member RIP
It is not about PCB's. It is about the ideal electrical transfer functions
looking nothing like any standard textbook electrical filters, used to
achieve with the drivers and box the correct acoustic responses.
rgds, sreten.
Old 17th December 2012, 03:38 PM   #20
csom's Avatar
Thank you sreten.
Could you please recommend some reading material in this regard so that I can understand it better?
I need them because my next work is to tune up my DIY Floorstanders. They sound very nice "by chance".
I need to know what more can I do to optimize their acoustic response.
Thank you for your feedback.
Warm regards, Som
Peamplifier and active crossover, working project geminni Solid State 11 6th October 2010 05:52 PM
AnAnalogue active crossover for speaker project! dogscanskate Multi-Way 16 31st December 2009 05:50 AM
3 Way Active Crossover Design project powagrip Multi-Way 13 23rd February 2005 08:06 PM
active crossover project victordsouza Multi-Way 0 9th September 2003 04:17 PM
Copyright 1999-2017 diyAudio
