DIY 3 way active crossover: as Christmas Holiday Project
Old 20th December 2012, 01:31 AM   #41
bibin3210 is offline bibin3210  India
Originally Posted by csom View Post
My previous post is lost perhaps because of Internet problem.
So I am posting it again.
Thank you so much bibin.
Much appreciated.
I made 3 layers ( top, bottom, drill hole ref ) from the download of that site, and gave it to a man who makes PCBs. Probably he is going to charge me a fortune but since this Project is well tested by our respected fellow members like Pra, Sudhir and many others, I decided to take the risk.
I might get the PCB the day after tomorrow if everything goes well.
If not, I definitely will take resort to your kind concern.
Thanks a lot, really, Bibin,
You are welcome CSOM.
Old 20th December 2012, 05:09 AM   #42
sudhir kumar is offline sudhir kumar  India
I have 2 questions here.
1. Very soon I am planning to buy a laser printer that is low cost, low maintenance, and suitable for my DIY PCB making.
Which Laser Printer do you recommend ?
2. At present I use laser tracing paper but I heard many good things about magazine paper on the net. But I am confused which Magazine ( or type of paper ) to use as there are many types of magazines available in India as you are well aware of and they use different types of paper .
Could you name a magazine that can be used for this purpose?
Thank you.
Sorry for replying late...I use my office laser printer for this purpose ..for home purpose you can use hp1007.
2. Magazines paper with medium thickness (less than copier paper) and glossy finish (means entire page is covered with printed material/ink) are best for this purpose.i.e the week,India today etc.
thanks.
sudhir
Old 20th December 2012, 05:32 AM   #43
Another question
How did you get the component reference on top layer on the PCB that you made as the photo of the top layer is not identical in size with the PDF of the copper layer?
Did you use a paper print and stick it on top?
I used Gimp to adjust the top layer coordination with the copper side but couldn't be able to get the correct size at first.
I somehow managed that finally.
HI,
I dont print component reference on top layer on pcb...I place the component just by comparing with given photo.
thanks
sudhir
Old 20th December 2012, 08:57 AM   #44
csom is offline csom
csom's Avatar
Thank you so much Sudhir. I will go for hp1007 very soon.
Now the concept of using magazine paper is crystal clear to me from the Indian Perspective. I was kinda lost earlier.
Thank you
Warm regards, Som
Old 21st December 2012, 05:06 AM   #45
Share your project when completed...I will also post my crossover photos..It is somewhere in my computer...i am in search..
thanks
sudhir.
Old 21st December 2012, 06:41 AM   #46
Here is my completed one using the same design:
Thanks,
Bibin
Old 21st December 2012, 10:06 AM   #47
csom's Avatar
Thank you Sudhir and Bibin.
Your photos will definitely help me as a good reference.
I've finished the PCB just now with the help of a friend.
Bottom layer is okay.
The drill reference points I made are okay too.
But the top layer is blurry as expected
Warm regards, Som
Old 21st December 2012, 12:42 PM   #48
csom's Avatar
Here is the Photo of 3 layers of the PCB, an example in case anyone makes the board with silk screen printing.
1. Bottom copper layer: Provided by the Author in the download.
2. Top component Layer: Provided by the author in the download and given only as a reference by the author to DIY-ers.
I resized, edited and aligned to fit the size of the PCB in my personal hobby project.
3. Drill hole reference Layer: I made it following the original author's design as I wanted to give the PCB a professional look
This layer can safely be ignored as redundant.
Warm regards, Som
Old 21st December 2012, 06:18 PM   #49
csom's Avatar
Thanks,
Bibin
Great work, Bibin!!
Warm regards, Som
Old 22nd December 2012, 01:57 AM   #50
Great work, Bibin!!
Thank you Som. How much did they charged for making the PCB?
Have you completed populating the PCB with all the components? Which amps are you going to use with this?
thanks,
Bibin
DIY 3 way active crossover: as Christmas Holiday ProjectHide this!Advertise here!
Peamplifier and active crossover, working project geminni Solid State 11 6th October 2010 06:52 PM
AnAnalogue active crossover for speaker project! dogscanskate Multi-Way 16 31st December 2009 06:50 AM
3 Way Active Crossover Design project powagrip Multi-Way 13 23rd February 2005 09:06 PM
active crossover project victordsouza Multi-Way 0 9th September 2003 05:17 PM
