| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
![]() Thread moved to more appropriate area.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#22 |
I'm sorry again Pinkmouse
and thank you so much
Warm regards, Som |
#23 |
Hi csom
check that pin 3 IC1A and the input connectors all have a ground connection as per (3 BAND EQ ) schematic . Last edited by epicyclic; 24th December 2012 at 11:48 AM. |
#24 | |
I compared the schematic and the PCB I made. They seem to be correct after I fixed my initial mistake as pointed out by Bobo. But still I will check it again as per your suggestion and report you back.
Warm regards, Som |
#25 | |
It is finally solved now. I had to interconnect ground tracks. My bad mistake. Now everything is working fine. I checked with output from cell phone, mp3 player, CD player, PC... all. ![]() Thank you really so much ![]() Wish you a happy new year
Warm regards, Som |
#26 |
Thanks for the problem solved post
Glad you got it working
| WTB 31-band graphic equalizer | Dave Jones | Swap Meet | 2 | 13th December 2010 08:31 AM |
| 5 Band Graphic Equalizer | NSLogan | Chip Amps | 2 | 17th June 2009 03:52 AM |
| DIY Graphic equalizer? | coldfuzion76 | Solid State | 4 | 18th March 2008 08:45 AM |
| Graphic equalizer | Buzzy | Parts | 1 | 24th July 2007 07:55 PM |
| Graphic Equalizer | Johnny25 | Parts | 5 | 29th March 2006 05:33 PM |
