GHOST in 3 band graphic equalizer!! SOS! - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th December 2012, 06:06 PM   #11
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
Originally Posted by csom View Post
I am lost as the el-caps are working perfectly with the 100k resistor but the bigger nonpolar ones ( which are dramatically improving the performance) fail.
The electrolytic has just enough leakage current such that it allows a DC path from the + input to the 47k resistor, the e-cap, and 100k resistor to ground. The film cap has very little (if at all) leakage current that's why the circuit no longer works with it.
Old 14th December 2012, 06:13 PM   #12
csom's Avatar
Thank you so much for your valuable input djQUAN.
I fixed the prototype as per the original circuit and everything is really nice sounding , with hardly perceptible noise even at the highest volume with the magic of NE5532.
Som
Warm regards, Som
Old 17th December 2012, 04:28 PM   #13
csom's Avatar
I have seen some manufacturers use electrolytic caps in graphic equalizer and audio amplifier kits in the signal path.
Just a question , if nonpolar caps are performing so nicely both at the signal input and output stage why the designer used electrolytic caps ? ( ref: post 1)
Is this a mere cost factor?
Warm regards, Som
Old 17th December 2012, 05:14 PM   #14
bobodioulasso's Avatar
Audiofools like to spend even if the difference is barely audible.
Old 17th December 2012, 05:45 PM   #15
csom's Avatar
LOL
I must be careful in future before I spend a fortune again , after this post.
Warm regards, Som
Old 23rd December 2012, 05:18 AM   #16
csom's Avatar
I found a new problem with the nonpolar caps I changed.
When the audio signal is fed from the output of the soundcard of the PC, it works very nicely and perfectly at a stretch without any problem.
But, when I connect cel phone, or other media player, the earlier low gain, sparking noise etc are reappearing again after some 2 minutes.
Could anyone kindly suggest how to fix that?
Thank you.
Warm regards, Som
Old 23rd December 2012, 06:38 AM   #17
csom's Avatar
Exclamation Strange.
This is the current situation.
Warm regards, Som
Old 23rd December 2012, 06:50 AM   #18
freax's Avatar
is the headphone output from the cell phone turned up too loud?
It could also be picking up transmissions from the cellphone... unavoidable unless you take extreme measures to shield the input.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 23rd December 2012, 06:54 AM   #19
csom's Avatar
Thank you so much freax for your response.
The output from the cell phone is not high. There was no overloading.
And the phone was connected in flight mode.
Warm regards, Som
Old 23rd December 2012, 08:19 AM   #20
csom's Avatar
Freax, I also checked with two other media players with the line out option.
But same problem.
With electrolytic caps everything is working but not with nonpolar input caps. ( and electrolytic caps are used in the original circuit ).
Warm regards, Som
WTB 31-band graphic equalizer Dave Jones Swap Meet 2 13th December 2010 09:31 AM
5 Band Graphic Equalizer NSLogan Chip Amps 2 17th June 2009 04:52 AM
DIY Graphic equalizer? coldfuzion76 Solid State 4 18th March 2008 09:45 AM
Graphic equalizer Buzzy Parts 1 24th July 2007 08:55 PM
Graphic Equalizer Johnny25 Parts 5 29th March 2006 06:33 PM
Copyright 1999-2017 diyAudio
