Request for Guides/Explanation Regarding Audio Mixer Circuits
Old 10th December 2012, 08:53 PM   #21
2ndIdentity is offline 2ndIdentity  Singapore
I used your recommended NE5532 for the op amp.
I am so excited right now.
Old 11th December 2012, 07:30 AM   #22
Mooly's Avatar
That's great well done
So whats next
Old 12th December 2012, 02:35 AM   #23
Currently trying to add LEDs to pulse along with the output!
Old 12th December 2012, 07:49 AM   #24
Mooly's Avatar
That's not as easy as it sounds, or more correctly, while its easy to get an LED to flash to the music, its less easy for it to be useful and meaningful.
Understand the problems and you'll see why.
Music has lots of transient peaks. So you decide you want an LED to light at a given level. Thats a problem because the transient nature of the signal means the light from the LED is transient too. In other words dim brief flashes when the signal exceeds some value.
What is nedded is a circuit to rectify the signal (so that peaks above and below "zero" are registered and treated equally and a circuit to add a time constant so that the peaks are "held".
Now all that can be done with a couple of opamps for one LED.
What I recommend is you consider a circuit based on the LM3914 series of chips.
Here's a great on-line resource for data sheets for 99% of the devices you'll ever need,
Datasheet catalog for integrated circuits, diodes, triacs, and other semiconductors, view
Look up LM3914, LM3915, and LM3916
If you look down the data sheet you'll see how the circuit is comprised of a chain of opamps each with a different fixed reference voltage on one input and the variable audio on the other.
Each opamp configured like that forms a "Window comparator"
Request for Guides/Explanation Regarding Audio Mixer CircuitsHide this!Advertise here!
mixer circuits (looking for simple, but very high quality)... dfeweer Analog Line Level 6 21st December 2011 10:58 PM
Explanation of superiority of Linux for audio? mr_push_pull PC Based 2 3rd December 2011 08:24 PM
Mixer Section explanation help needed. graygem Analog Line Level 1 12th May 2011 05:56 PM
mixer circuits jonathanmatenga Multi-Way 1 9th August 2007 08:01 PM
request for an explanation of "Q" jaygeorge1979 Multi-Way 11 19th January 2006 07:56 AM
