Yet Another IR Remote Volume Controller? No, I want one WITHOUT uC
Old 4th December 2012, 06:10 AM   #11
balerit is offline balerit  South Africa
balerit's Avatar
Originally Posted by gmphadte View Post
All u want cannot be achieved easily without using a preset equaliser chip. U can do it with motorized pots but will be costly and getting the pot value will be difficult to replace in an existing circuit. However fade in and fade out will pose its own issues.
Gajanan Phadte
Will it be that difficult? I'm sure the guys who write pic programs will be able to write a program that will take the remote controls input, say for volume, and output it as a voltage on the relevent pin.
http://novelbooks.weebly.com/camm-eq...amplifier.html
Old 5th December 2012, 11:56 AM   #12
gmphadte is offline gmphadte  India
You will need four DACs for four outputs.
Gajanan Phadte
Old 13th December 2012, 05:03 AM   #13
sunrom.com sells remote controls and other useful items. U can always buy four motorised pots and control it from these using some H bridge ICs.
Gajanan Phadte
Old 13th December 2012, 06:23 AM   #14
balerit's Avatar
It's possible to output a pwm voltage with a pic to give a variable voltage, it only needs between 0 and 5 volts.
Old 24th April 2013, 08:47 PM   #15
CaptainWatt is offline CaptainWatt  United States
CaptainWatt's Avatar
Originally Posted by yagoolar View Post
I want to add an IR remote volume controller to my tube amp (C3g+6C4C). There are a lot of circuits based on microcontrollers (AVRs, PICs, '51s etc.), but I have found 0 (zero) pure analog ones. Are there any special funtion IC, e.g. RC5 decoders, or discrete solution I can utilise to control an Alps RK168 series potentiometer?
Hi there. Stumbled across this old thread you started and wanted to ask why you're trying to avoid a uC based IR remote volume controller? Are you concerned about noise?
I've personally developed a preamp controller product that utilizes a uC to handle IR remote decoding as well as other things on a DIY preamp board as well as fully integrated preamp product. They happen to utilize LDRs (light dependent resistors) so the audio signal and control signals are both electrically and optically isolated. Noise has not been an issue.
Having built a uC based IR decoder I had to get intimately familiar with the details of how IR signals work and how to detect and decode them. While I'm no analog circuit design maven I can't imagine doing this in a purely analog fashion. It requires a precise timer and interrupt driven logic. Even a specialized IC will still be essentially a digital device - a specialized uC if you will.
Best,
Morten
Tortuga Audio - Handcrafted high performance audio gear for music lovers
Old 24th April 2013, 09:47 PM   #16
tauro0221 is offline tauro0221  United States
I think you can use the TA7330P by using Digital Potentiometer for each control and a micro. The only problem it is finding the right digital potentiometer that match your control resistor. Analog device have some but they are increment of 5K,10K,50K 100K. The micro can read the remote code and then adjust each potentiometer. I do not think it is to hard to built.
Old 29th April 2013, 11:34 PM   #17
Pano is offline Pano  United States
Pano's Avatar
You'd have to build your own remote, too - wouldn't you?
How about something based on the method used for RC cars and planes? At least in the old days they just used a carrier and varied the phase of a pulse. That should be easy enough to adapt to IR. Or maybe just use the RF control and receiver along with some model servos.
Take the Speaker Voltage Test!
Old 30th April 2013, 12:57 AM   #18
Don Hills is offline Don Hills  New Zealand
You can do it all analog, but it won't be the cheapest way.
- Build a simple IR remote control that generates two different frequencies. Modulate them onto a standard 38 KHz carrier. For example, it might emit a 1 KHz signal for volume up and 2.5 KHz for volume down.
- Use a standard IR receiver chip. Couple the output to two tuned filters, one for 1 KHz and one for 2.5 KHz.
- Use the filter outputs to drive an H bridge connected to the pot motor.
This is the same scheme as used by some cheap radio-controlled toys. In fact, you could probably use the electronics from one and wire the receiver's motor drive outputs to the pot motor...
If you do this, you can remove the transmitter's circuit board and mount it in a more stylish case. You won't need an external aerial for short ranges. When shopping for one, look for one without a separate on/off switch on the transmitter. This type only powers the transmitter when a button is pushed. Some of the ones with on/off switches run the transmitter continuously and will discharge the battery if left on. (Some have the switch but do not transmit contiuously, but you can't easily tell without disassembling it.)
Old 30th April 2013, 01:18 AM   #19
I found another chip that you can use for your project. It is require 2 contact one for up and one for down. The chip is the Dallas DS1669. It is easy to interface.
Old 30th April 2013, 11:51 AM   #20
Pano's Avatar
How about DTMF? Telephone tones. The chips are cheap and easy to find. 10 functions.
Or maybe one of the early, crude TV methods. A photo-cell at each corner of the chassis. Depending on which one you hit with light, volume would go up or down. You could use a laser pointer to hit the target. I've been able to turn off streetlights with a laser pointer, you should have no trouble.
Yet Another IR Remote Volume Controller? No, I want one WITHOUT uCHide this!Advertise here!
PGA2311 Stero Remote Volume Controller Preamp diyhifishop Vendor's Bazaar 18 11th February 2017 01:57 AM
NEW Remote Volume Controller- 10 SETs bbp Swap Meet 79 19th December 2009 06:35 PM
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 03:44 PM
need help with IR remote controller sss Everything Else 7 24th November 2005 01:00 AM
DIY IR remote volume control addon emorysmith Everything Else 17 31st May 2005 07:36 PM
