Need help: Input selector control for 6 channels
Old 27th November 2012, 08:48 AM   #1
diarav is offline diarav  India
Default Need help: Input selector control for 6 channels
Hi All,
I am building a 6 channel amp for home theatre. This will also be capable of playing music from 2 channel sources like iPod, other external sources.
I am planning to implement a simple source selectr using a 2 pole rotary switch. The L/R channels will be selected from the rotary switch.
My concern is the remaining 4 channels from the DVD which must be activated and sent through only when the source selected is DVD. I am looking for ideas where I can perhaps compare the input and output signals and if they are identical/similar, then get the four channels active else they are disconnected from the amp. But I am not an expert in electronics and only a part time hobbyist, I would appreciate pointers to any circuits that might help me here.
I do understand that the best way is to switch off the DVD when not in use, but atleast as a user it would good to have it implemented clean.
Thanks in advance.
Din
Old 27th November 2012, 09:32 AM   #2
sofaspud is offline sofaspud  United States
sofaspud's Avatar
When you say "planning to implement" does that mean you haven't obtained parts yet?
(Just the pic with no description shouts, "Houston, we have a problem.")
You could use the rotary positions to switch relays.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 27th November 2012, 11:08 AM   #3
First of all thanks for your response.
I have already built the 6 power amps using LM3886, power supply and they are working fine. In the pic below I have only tried to isolate the issue I am trying to address. All other parts of my amp are nearly ready. I tried building an input selector using CD4066 and found issues (mostly cross talk) - not sure if the chips were bad. I decided to go with a mechanical selector option. I am keeping the relay as a last option, and I intend using the 2 pole rotary since it is simple.
Din
Old 27th November 2012, 11:31 AM   #4
sofaspud's Avatar
And finding that it isn't quite so simple after all? Aside from relays or a 6-pole switch, the only other thing I can think of is adapting an Auto-On circuit (the kind often found in active subwoofers) for the extra channels. I'm not even sure that would work, and it's really just solid-state switching. From what I recall of CD4066 performance, it isn't that great for this application. There may be more modern alternatives with improved specs.
Old 27th November 2012, 07:54 PM   #5
Wayne Parham is offline Wayne Parham  United States
Wayne Parham's Avatar
Check out BuildAnAmp.com. They have a remote control kit that will provide switching for six channels, as well as passive line level attenuation using an Analog Devices AD5206 attenuator. It will give you manual or remote control switching and/or attenuation.
Visit the π Speakers website
High-quality audiophile loudspeakers and kits
Old 27th November 2012, 11:33 PM   #6
linuxworks is offline linuxworks  United States
linuxworks's Avatar
I could suggest the lcduino from amb.org (ob disc: I worked on the design). it can do up to 8 relay selected inputs and its controller code is open so you could create special mappings that 'know' about 5.1 audio vs 2.0 audio. it could then do various special things with extra relays. the inputs are name-able on the lcd display and the code is arduino-based so its not hard or expensive to change things if you want.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 28th November 2012, 12:40 AM   #7
sofaspud, Wayne, linuxworks,
Thanks for your inputs. I will look into it.
Din
Old 29th November 2012, 07:23 AM   #8
Hi All,
I had a look at the suggestion and they seem to be pointing to readily available solutions. I was more keen on looking a something more simpler.
With some bit of thinking, I added a few more elements to my block diagram. If someone can let me know if this approach can work.
What I am trying is to connect the output of say the left channel to the +ve of the OpAmp and the left channel of the DVD input to the -ve. If both signals dont match, that is if the output from the rotary switch is from a different source other than DVD, we should have some signal at OpAmp output which is further rectified. If both signals match we should have zero output at OpAmp output. With this logic I am hoping to control the analogue switch for the four channels.
While I am still experimenting, I would appreciate any inputs to suggest if I am in the right direction and any ideas to supplement the same.
Thanks in advance.
Din
Need help: Input selector control for 6 channelsHide this!Advertise here!
M62439SP - Selector and tone control MrBlc Parts 2 17th November 2013 12:28 PM
help with my volume control, input selector, and other questions jufreese Chip Amps 5 26th March 2009 04:39 PM
how to control 6 channels using one pot Tambourine Man Chip Amps 26 16th November 2007 05:07 PM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
Fort those needing 6 channels of volume control PHilgeman Multi-Way 1 9th June 2004 08:30 PM
Copyright ©1999-2017 diyAudio
