Convert mini Pre-amp from AC to DC power - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th November 2012, 12:53 AM   #11
I tried to bypass the regulator and that still does not work. I bypassed the pre-amp to make sure my source and amp were working and everything is good. I also checked my supply voltage and its perfect.
Hopefully there is some way??
Or I guess I need to find another solution. I need a small pre-amp for my amplifier.
MP
Old 25th November 2012, 06:15 AM   #12
sofaspud's Avatar
You must be doing something wrong, or something is being overlooked by someone.
I took another look at the preamp board - bridge rectifier, feeding the 78L12 and 79L12 regs, powering the single DIP8 op amp package. Sorry, but my money's on the former.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 25th November 2012, 10:25 AM   #13
AndrewT is online now AndrewT  Scotland
blown opamp due to error in trying to connect the wrong PSU at the start.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th November 2012, 07:41 PM   #14
Sofaspud,
Are you saying it should work with DC power supply? Or do you think its possible that I blew the op amp like AndrewT says?
Mike
Old 25th November 2012, 09:31 PM   #15
sofaspud's Avatar
It is made to work with DC. This mod was only providing the DC differently.
It may be possible. I don't know what you've hooked up to the circuit trying to get it to work.
Old 9th September 2015, 02:48 PM   #16
asilker is offline asilker  United States
asilker's Avatar
I ordered the same kit and I'm trying to figure out how to power it. As I'm new to electronics, I'd be interested to hear if you figured this problem out.
My plan was to power the board with a laptop power supply, but it seems the DC voltage is not compatible with the stock board and I should look for a 12-0-12 power transformer with low amp rating?
help I'm an electronics baby!
Old 9th September 2015, 03:12 PM   #17
Did it Himself
richie00boy's Avatar
To use a DC source such as a laptop power brick you need either a negative rail generator or a supply splitter.
Or a 12-0-12 transformer. The board already has bridge rectifier and smoothing capacitors.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 9th September 2015, 03:29 PM   #18
asilker's Avatar
Thanks for the clarification. I just ordered a 12v-0-12v transformer. I'm really excited about trying this project. I'm a little nervous that none of this will work and I'll have to scrap it, but I'll be awfully proud of myself if I can make a functional piece.
Old 9th September 2015, 03:34 PM   #19
theAnonymous1's Avatar
Isolated DC-DC converters in handy for applications like this....
Astec Dual DC DC Converter 9 18V 1 23A to 12V 230mA AA05E 012L 120D | eBay
Some external filtering cleans up the small amount of ripple/noise quite well and their small size is a bonus.
Convert Gates pre-amp to DC filament? slor Tubes / Valves 16 29th October 2011 05:18 AM
chip amp with 12v DC AND 240v AC power supplies? Vital AV Chip Amps 19 15th November 2009 11:39 PM
we can offer power module of DC/DC Converter & AC/DC Adapter auling Vendor's Bazaar 0 12th May 2009 04:48 AM
Convert Dac from AC to Battery Power recca Power Supplies 2 20th August 2007 01:25 AM
Combined PFC AC/DC & DC/DC SMPS ChocoHolic Power Supplies 33 22nd December 2005 11:04 PM
Copyright 1999-2017 diyAudio
