| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#51 |
#52 |
#53 |
RNM I have to find out how to simulate CMR, I am quite new in spice simulation.
The main noise contributor is current conveyor input resistor(R28). Changing BC5.. transistors to 2sa970/2sc2244 dropped the noise from 40nV/sqrtHz to 37nV/sqrtHz only. To have the same gain with lower input resistor I changed CM to equal current in both legs and here is simulation I called low noise low distortion. Additional benefit is lower dissipation of Q6 and Q8 and there are low power transistor good enough now. If I want to keep that low noise high impedance input volume control is no no. Output resistor(Rout) could be used as an atenuator but 1k only and that is not easy to get by. Any suggestion?? Damir |
#54 |
Noise and distortion simulation by changing current conveyor output resistor(R1(Rout)) from 100 to 1000 ohm in ten steps, changing the gain from 0.46 to 4.6.
Damir |
#55 |
you can replace Q3 and Q4 and diodes by complicated buffer as enployed in input and output.
by the way, if you do not intend to use global loop feedback,as CFB opamp, it may be easy to obtain better performance with folded cascode instead of current mirror. there are some discussions about similar circuit. Zen -> Cen -> Sen, evolution of a minimalistic IV Converter dac I/V convertion with very low distortion |
#56 |
There are two examples of the line amps that I think could be good to be built. Both are very close regarding distorstion and noise. Here is the first one. Input 0.3 V and 0.01 V.
Which one to build? dado |
#57 |
The second one, same input voltage.
dado |
#58 |
#59 | |
There are two schematics only, shown with two different input signals, and you can see all details of the schematics by clicking on the down left corner. Damir |
#60 | |
Yes I know, and from the two I would gladly chose the second one with absent of 7th harmonic ![]() Well after it'll be built .... yes the PCB design, components influences, and all related other parasitics will take their places would surely be different but for sure this is very, very good starting point and the final proto might even surprise you with the very low distortion sound ![]() Best regards, Andreas |
| The InSense Current Conveyor | bcarso | Digital Source | 17 | 20th August 2012 09:11 AM |
| An inverting current conveyor approach | bcarso | Digital Source | 0 | 30th July 2012 06:12 PM |
| High voltage, low current output stage for class D amplifier | ionomolo | Class D | 45 | 15th February 2011 06:03 PM |
| voltage vs current | Raj1 | Solid State | 1 | 12th June 2004 05:35 AM |
