Current conveyor as a voltage amplifier - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th November 2012, 10:42 AM   #21
keantoken's Avatar
I found this to work the best for limiting, and impact on distortion at 1V output is very small.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 24th November 2012, 12:51 PM   #22
dadod is offline dadod  Croatia
dadod's Avatar
I would like to have higher clipping limit and I used three dodes string do get that, but distortion incresed to much for my taste. With LED insted 1N4148 is a bit better bur still to much.
dado
Old 24th November 2012, 12:52 PM   #23
dadod's Avatar
Lower FFT is with no clipper connected.
Old 24th November 2012, 01:00 PM   #24
keantoken's Avatar
It looks like you have Rout very high. I have it at 2k. For me THD only increased 6db or so at 1V output.
Try moving the diode limiter to Vout2. Then put antiparallel diodes between Vout and Vout2. The antiparallel diodes acts as an output current limit which engages when the voltage limiter conducts. The current limit will engage at 18mA for silicon, 9mA for schottkey. The voltage limiter will cause less distortion because it is now at a low impedance node.
Old 24th November 2012, 02:10 PM   #25
dadod's Avatar
Rout was set to 560 ohm for that simulation.
Old 24th November 2012, 02:19 PM   #26
keantoken's Avatar
If you need more limit voltage, don't add diodes to the limiter. Instead add diodes above R17; this way the limit will be more abrupt and the diodes won't have to share the reverse bias. I have R17 at 5.6k - but I doubt this matters.
Old 24th November 2012, 02:36 PM   #27
dadod's Avatar
You mean above R17 and below R13? It did not change anything and how it could!
Old 24th November 2012, 02:47 PM   #28
keantoken's Avatar
The bottom of D6 should be connected below the new diodes.
Old 24th November 2012, 04:01 PM   #29
dadod's Avatar
It is better now, it seams that R13, R17 with 5.6k value give much lower distortion before clipping.
dado
Old 24th November 2012, 04:12 PM   #30
keantoken's Avatar
Great!
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 10:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 07:12 PM
High voltage, low current output stage for class D amplifier ionomolo Class D 45 15th February 2011 07:03 PM
voltage vs current Raj1 Solid State 1 12th June 2004 06:35 AM
Copyright ©1999-2017 diyAudio
