Current conveyor as a voltage amplifier - Page 26 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th August 2013, 01:00 PM   #251
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by RNMarsh View Post
What can you guys do with this? SIM it and add what is needed for output stage etc.
It uses cancellation technique to reduce distortion. [I'm into cancellation circuits now]
Then bend it into push-pull input etc.... .
Thx-RNMarsh
Attachment 364749
I am trying to simulate the schematic from the patent, but patent description, mildly said, is confusion. What means “a reflected base current”?
The output stage there, in my opinion is just to hide the patent real thing. Why patent description should be so cryptic.
I tried the simulation but was staked. Does anyone have an idea how it actually should work? what resistor values to use?
Whole patent description attached.
BR Damir
File Type: pdf cancelation circuit patnum US20090256634A1.pdf (45.1 KB, 146 views)
Old 19th August 2013, 09:06 PM   #252
keantoken's Avatar
I've simulated it but there seemed to be instability caused by positive feedback and I couldn't get it stable.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 12th October 2013, 04:52 AM   #253
cast is offline cast  China
Old 12th October 2013, 05:16 PM   #254
dadod's Avatar
why have you sent this???
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 10:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 07:12 PM
High voltage, low current output stage for class D amplifier ionomolo Class D 45 15th February 2011 07:03 PM
voltage vs current Raj1 Solid State 1 12th June 2004 06:35 AM
Copyright ©1999-2017 diyAudio
