Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th February 2013, 06:00 AM   #201
bcarso is offline bcarso  United States
Originally Posted by smms73 View Post
Dado it looks very good
How about using those supertex depletion mosfet in place of the jfet's? They have higher early voltage than the 2sk170 at those low Vds. I just do not know if they are noisier.
I will buy some of this deplection mosfets for triyng some ideas.
You can also cascode the main current sources for higher output impedance of the ccs. But your regulator is very good as it is.
They are a bit noisier, especially at low frequencies.
Old 18th February 2013, 07:30 AM   #202
dadod is online now dadod  Croatia
dadod's Avatar
Originally Posted by keantoken View Post
There is a way to find out.
I will try to explain why I think it was not good idea at least for my shunt regulator.
1. I whant to regulate both sides + and - with one trimer for that.
2. I tried not to uze zener diode as reference(used in Borbely simple shunt reg) as that defeat poit 1.(and it is noisier).
3. Output impedance is low enough, a wires could input higher impedance.
4. To spare a diodes is not so important as above points.
dado
Old 18th February 2013, 07:40 AM   #203
dadod's Avatar
Thanks ssms73,
I have a bunch of different small jfets and only TO220 supertex type, and they are noisier as bcarso pointed out.
Cascoding of the ccs, I think, is not very needed.
dado
Old 19th February 2013, 11:39 PM   #204
smms73 is offline smms73  Portugal
smms73's Avatar
I was afraid of that. anyway I will buy some to experiment.
Sérgio Santos
Old 19th February 2013, 11:44 PM   #205
smms73's Avatar
dado
Walt jung have writing some articles about current sources to use with regulators.
Services
Sérgio Santos
Old 20th February 2013, 12:56 AM   #206
Walt's recommendation was the reason I tried them and tested them in fact. They are not too bad, but there is no guarantee, no specification for noise, and it is highly process-dependent. But those Supertex parts I tried were not as bad as I feared and would be quite adequate for many situations (like plate loads for hybrid tube circuits, which was my application at the time).
Brad
Old 20th February 2013, 01:13 AM   #207
keantoken's Avatar
You're right Dadod, I didn't think about how the zener would act as a reference. I'm a total go for the regulator as it is, FWIW. Keep up the good work.
Old 20th February 2013, 05:33 AM   #208
dadod's Avatar
Thanks Kean, I appreciate your support.
Old 1st March 2013, 09:28 AM   #209
dadod's Avatar
Discussion, in an other thread, about the need to have SUPER HIGH bandwidth was the reason to do some FFT simulation at 20kHz, 100kHz and 1MHz.
Here are the simulations only, I hope that the real result will be not far from it.
dado
Old 1st March 2013, 06:29 PM   #210
MiiB is offline MiiB  Denmark
Sergio.. would it be possible to make something like the circuit in post #180 with balanced in..??
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 09:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 06:12 PM
High voltage, low current output stage for class D amplifier ionomolo Class D 45 15th February 2011 06:03 PM
voltage vs current Raj1 Solid State 1 12th June 2004 05:35 AM
Copyright ©1999-2013 diyAudio
