| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#191 | |
#192 |
#193 |
This is the shuntreg PCB, suggestions welcome.
dado |
#194 |
This is finall tested shunt regulator version. I built one channel for now, tested it with no load and with a load and it looks stable and no visible riple or high frequency oscilation.
Now I have to assemble second channeland test it with the lineamp(GainWire). dado |
#195 |
You could integrate D3 and D5 with R3 for lower DC impedance and less parts.
#196 |
#197 |
Replace R3 with D3 and R22.
#198 |
#199 |
#200 |
Dado it looks very good
![]() How about using those supertex depletion mosfet in place of the jfet's? They have higher early voltage than the 2sk170 at those low Vds. I just do not know if they are noisier. I will buy some of this deplection mosfets for triyng some ideas. You can also cascode the main current sources for higher output impedance of the ccs. But your regulator is very good as it is.
Sérgio Santos |
| The InSense Current Conveyor | bcarso | Digital Source | 17 | 20th August 2012 09:11 AM |
| An inverting current conveyor approach | bcarso | Digital Source | 0 | 30th July 2012 06:12 PM |
| High voltage, low current output stage for class D amplifier | ionomolo | Class D | 45 | 15th February 2011 06:03 PM |
| voltage vs current | Raj1 | Solid State | 1 | 12th June 2004 05:35 AM |
