Current conveyor as a voltage amplifier
Old 2nd February 2013, 03:50 PM   #181
smms73 is online now smms73  Portugal
smms73's Avatar
Originally Posted by dadod View Post
Regarding power supply, there is oppinion that nothing can beat good shunt regulator and I need to lower power voltage to as mine transformer has 2x30V.
Damir
That is a myth , one of many in Audio.
But of course they are very good , and the current source helps a lot. But they are the worst in respect to power efficiency, and that is the reason I do not use it . The regulator that i use have very low noise and is more efficient.
Sérgio Santos
Old 2nd February 2013, 04:40 PM   #182
dadod is offline dadod  Croatia
dadod's Avatar
Efficiency is very low, but this is line preamplifier and I never used shunt regulator yet, and I want to see haw that myth stand against serial regulators.
Old 2nd February 2013, 04:58 PM   #183
bcarso is offline bcarso  United States
diyAudio Member RIP
Here is new shuntreg simulation. I am trying to keep just one jfet ccs as in this case output voltage adjustment is possible with one trimer(R7 in this case). Here CCS voltige is 2.2 V and I think its on safe side of the knee(in saturation region).
dado
Yes, that's one way to get the voltage across the 170 larger. I also like the bypassing of the resistors with the 47uF, for lower noise, but be aware that for a fault condition on one of the outputs, say a dead short to common, the bipolar base associated will be abruptly reverse-biased and break down. This typically will result in beta degradation. So a diode connected across the b-e junction to clamp against reverse voltage is a good precaution.
To the comment about inefficiency of shunt regulators: yes, indeed so. In an eight-channel system I designed for a client, the overall power dissipation was constant. At 200W! And it was not a power amp! Someone in the audience of three (it was early in the morning on the last day of an AES convention ) frankly disbelieved this at the time.
What is particularly effective for achieving a combination of low susceptibility to RF without a sacrifice of audio frequency performance: local shunt regulators near portions of the circuit that have variable current consumption with signal levels. This permits the use of ground planes where they would otherwise compromise performance. I believe Putzeys has endorsed this approach somewhere, although many have used it for years (some instrumentation I did, not audio, in the 1970s for example).
Old 2nd February 2013, 05:42 PM   #184
diyAudio Member RIP
One more caveat that occurs: again, under fault conditions, the power DMOS parts can see out-of-spec magnitudes of gate-source voltages. Although zeners for protection are somewhat high capacitance, you could bias one "on" and use a small signal diode like a 1N4148 to be normally reverse-biased and only clamp a gate for a good-sized but in-spec overvoltage condition.
Old 2nd February 2013, 05:53 PM   #185
smms73's Avatar
bcarso , do you mean using a single current source and then use various shunts near the various parts of the circuit ?. I also like ground planes.
200W and not an amplifie r, that is a huge waste of energy, we consume this world resources like mad man´s.
Sérgio Santos
Old 2nd February 2013, 06:46 PM   #186
diyAudio Member RIP
Actually quite a few current sources. To be precise though, the local shunt reg approach was not followed as much with the 200W behemoth as with some other systems I've done over the years.
And if it is any consolation, from the standpoint of squandering resources, Harman R&D ran out of money, so the 200W system was never completed. It would have cost another 20k to finish, and they would have had to let a secretary go.
I don't know what they wound up using, I think some bog-standard thing from Audio Authority, but since most of the group don't think that one can hear nuances in electronics very well anyway, I'm sure they were satisfied They are still my friends
The system was to be used to compensate for loudspeaker efficiencies, so that double-blind tests using their speaker mover would have each presentation at equal SPL. The line level gains were adjusted based on previous pink noise measurements, and the system faded down and up between step changes in overall gain, with the fader circuitry completely bypassed thereafter. My goal was to do 144dB maximum balanced output signal to zero-signal noise, and it almost managed that (one channel was completed and measured). Vishay S102s were switched with mercury-wetted reeds, with various silicon ahead and behind the attenuators. I would do things a bit differently today
Old 2nd February 2013, 08:34 PM   #187
dadod's Avatar
Thanks bcarso, I will do as you suggest.
Damit
Old 2nd February 2013, 08:42 PM   #188
dadod's Avatar
Sorry bcarso, by DMOS I suppose you mean deplation mode MOS(DN2540)?
Damir
Old 2nd February 2013, 08:49 PM   #189
dadod's Avatar
Actually I was not saying the trouth, I am using it in the Orion analog crossovers.
Old 2nd February 2013, 10:25 PM   #190
diyAudio Member RIP
Damir
I'm more worried about the shunt ones. If the bipolars momentarily saturate or swing too much the gate-source voltage magnitudes get big. |20V| is usually the momentary maximum, or you puncture the oxide and it's all over. For continuous bias usually |10V| is about as high as recommended.
Of course if no fault condition ever occurs, you'll be fine. But it's very demoralizing when bringing a new board up and some errant condition pops one of the parts
Current conveyor as a voltage amplifierHide this!Advertise here!
High voltage, low current output stage for class D amplifier ionomolo Class D 46 30th December 2017 11:35 PM
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 09:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 06:12 PM
voltage vs current Raj1 Solid State 1 12th June 2004 05:35 AM
