Current conveyor as a voltage amplifier
Old 1st February 2013, 09:19 PM   #171
smms73 is offline smms73  Portugal
smms73's Avatar
Mirror_bjt.asc I have post the models in here already.
Sérgio Santos
Old 1st February 2013, 09:47 PM   #172
smms73's Avatar
I have change the value of R2 for 500 and 250 ohns to change the gain to 8 and 16.
the results are with 8 X
0.000027% 4 Vp-p out
0.000072% 8 V pp
0.00025% 16 Vpp
with 16X
0.000039%
0.000111%
0.000392%
Even with a gain of 32x the distortion is only 0.000086 at 4 volts p-p out.
It seems that voltage gain is not a problem.
Sérgio Santos
Old 1st February 2013, 10:52 PM   #173
keantoken is online now keantoken  United States
keantoken's Avatar
Connect the collectors of Q16 and Q18 to ground. They only add distortion.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 2nd February 2013, 06:13 AM   #174
dadod is offline dadod  Croatia
dadod's Avatar
Thanks Sergio.
Old 2nd February 2013, 07:05 AM   #175
dadod's Avatar
Sergio, I think that your circuit is really excellent demonstration of an engineering skill. I don’t know you but I am glad that you participate in this thread. I know about Keantoken a bit more and followed his fascinating progress in this forum. I am just an old retired telecommunication engineer and audio is my hobby to kip my old gray matter oiled. What I learned more then forty years ago about semiconductors now slowly is coming back and I started to use spice simulator not so long ago.
What do you think if your circuit could be made simpler whiteout loosing to much of its performance, still distortion could stay in ppm region?
Another thing to make it with high gain, let say 20 to 30 dB and then add powerful output buffer to get power amp with no GNFB. I was trying to simulate an output buffer(trying different configuratio) but never was satisfied with distortion level.
Damir
Old 2nd February 2013, 11:35 AM   #176
dadod's Avatar
Here is new shuntreg simulation. I am trying to keep just one jfet ccs as in this case output voltage adjustment is possible with one trimer(R7 in this case). Here CCS voltige is 2.2 V and I think its on safe side of the knee(in saturation region).
dado
File Type: jpg shunt-regulator-double-output-impedance-II-b.jpg (244.5 KB, 233 views)
Old 2nd February 2013, 12:23 PM   #177
smms73's Avatar
Originally Posted by keantoken View Post
But A and B perform the same when you have 220/75 degeneration. Do you know of a better way to increase gain?
A 220/75 degeneration ratio will imbalance the mirror, and it will lose some distortion cancellation property.
one way to do the job without loosing balance is like this , the penality is adding 2 bjt and 2 resistors.
Sérgio Santos
Old 2nd February 2013, 12:45 PM   #178
smms73's Avatar
Thanks Damir for your kind words, I'll try to do what you ask , but the components used here are really cheap , the 20 transistors used in this circuit will cost less than a dollar. I do not really see the problem
About the power supply , have you consider The Kmultiplier from Kean, I use a very similar soluction ,It is really very low noise, and have very good stability , and is less complex than the one you are doing. But the output impedance is a bit higher.
Sérgio Santos
Old 2nd February 2013, 02:29 PM   #179
dadod's Avatar
Someone said the less is better, and Einstein said " Everything should be made as simple as possible, but not simpler". OK it is question of PCB too, simpler to make.
Regarding power supply, there is oppinion that nothing can beat good shunt regulator and I need to lower power voltage to as mine transformer has 2x30V.
Damir
Old 2nd February 2013, 03:32 PM   #180
smms73's Avatar
Here is a similar circuit but with current sources instead of current mirrors.
I cut some of the fats, to get it in accordance with Einstein
The distortion is 0.000069% at 4 V p-p with a gain of 16x
One of the advantages of using current sources like that is that the psrr is higher, I have made circuits with this topology with psrr of 80db.
Sérgio Santos
Current conveyor as a voltage amplifierHide this!Advertise here!
High voltage, low current output stage for class D amplifier ionomolo Class D 46 30th December 2017 11:35 PM
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 09:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 06:12 PM
voltage vs current Raj1 Solid State 1 12th June 2004 05:35 AM
