Current conveyor as a voltage amplifier
Old 1st February 2013, 08:22 PM   #161
keantoken is offline keantoken  United States
keantoken's Avatar
Output impedance is still 4K; not comparable to Dado's circuit. Gain is 4. C8 and C4 should go to their respective rails as they decrease RF PSRR. How is THD with 25k source impedance?
For AC/step response a plain Bode plot is not very useful. Plot group delay by changing the right side scale or plot Tg(Vout). When this is smooth there will be no small-signal AC or step response anomalies.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 1st February 2013, 08:26 PM   #162
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by smms73 View Post
Using the "B" type of current mirror gives 0.000029%
The "A" type give 0.000125%
A good improvement.
I used "B" type CM in my TT amp. Here distortion is already so low that trying to make it lower adding more transistor in my opinion is not so good idea.
Old 1st February 2013, 08:42 PM   #163
smms73 is offline smms73  Portugal
smms73's Avatar
Kean if i construct this, I intend to use the volume control in the output so I will use (10K) , followed by a buffer. A gain of 4 serves my needs . Are you sure about the PSRR ? By my experience this way is better, but i will give it a try. Thanks by the tips.
Sérgio Santos
Old 1st February 2013, 08:51 PM   #164
smms73's Avatar
Dado have you measure your circuit in real life ? Simulations are only as good as the models we use , i tend to use bc327 and bc337 because they give me results close to the reality, if you use the models 2sa1381c 2sc3503c from bob cordell you will have very good distortion results in sim , but not so good in reality.
Sérgio Santos
Old 1st February 2013, 09:03 PM   #165
keantoken's Avatar
A good improvement.
But A and B perform the same when you have 220/75 degeneration. Do you know of a better way to increase gain?
Old 1st February 2013, 09:06 PM   #166
keantoken's Avatar
Early voltage changes with operating point. Some transistors even have a negative early voltage at specific operating points. So perhaps Cordell's model is a compromise. Furthermore, perhaps the 2SC3503 and KSC3503 are not very similar in this respect?
Old 1st February 2013, 09:07 PM   #167
smms73's Avatar
curves from 2sc3503c from bob cordell (green) and bc327 (blue), if you use 2sc3503c in sim you will have much better results , but this transistor is very good , it has a hight early voltage and low noise, but low Hfe , i like it very much , but i think the models are not correct.
Sérgio Santos
Old 1st February 2013, 09:07 PM   #168
dadod's Avatar
I did not measure my circuit just I've done some listening with temporary power supply.
Please post LTspice files with all models you use, and I can compare.
You said it is your best result wit current mirrors, or you meant with current conveyor?
Current mirrors convey a current from one side to other with very low distortion.
In my circuit its easy to get a gain of 4 and lower distortion with it.
Be careful with volume control at the output, it will change the gain(it's conveyor).
By the way have you red this thread from beginning, there som more circuit presented?
dado
Old 1st February 2013, 09:13 PM   #169
smms73's Avatar
Kean I have ask Joachim to measure a pair of sanyo 2sc3503 and 2sa the result is here:
MPP
Very good transistors.
Sérgio Santos
Old 1st February 2013, 09:19 PM   #170
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by bcarso View Post
Or, short of that, you could use DMOS parts with a few volts of threshold in place of the bipolars. Unfortunately the low frequency noise will usually be higher, and the transconductance lower, compared to the bipolars. Candidates if used might be the ZVN3306 and ZPN3306.
Correction: should have typed ZVP3306 for the P channel part.
Current conveyor as a voltage amplifierHide this!Advertise here!
High voltage, low current output stage for class D amplifier ionomolo Class D 46 30th December 2017 11:35 PM
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 09:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 06:12 PM
voltage vs current Raj1 Solid State 1 12th June 2004 05:35 AM
