Current conveyor as a voltage amplifier
Old 28th January 2013, 06:09 AM   #121
padamiecki is offline padamiecki  Poland
Thumbs up congratulations!
Originally Posted by dadod View Post
Finally I did first listening.
I am still impressed from the first post of your thread
regards, Pawel
Old 28th January 2013, 11:11 AM   #122
dadod is offline dadod  Croatia
dadod's Avatar
Thanks Pawel
Old 28th January 2013, 01:35 PM   #123
keantoken is offline keantoken  United States
keantoken's Avatar
Hey Dado. I should have looked this up sooner. Here is what Edmond did to bias the Baxandalls. Look at R12 and R14 in Figure 5:
Super TIS
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 28th January 2013, 02:52 PM   #124
dadod's Avatar
Super TIS
Kean, but Q7 an Q8 are biased differently. Do you have suggestion for that? Changing it according R12 and R14 did not change anything.
dado
Old 28th January 2013, 03:49 PM   #125
keantoken's Avatar
Nevermind Dado, there is no point in applying Edmond's scheme to this design because of the unequal current mirror ratios.
Also, you may acknowledge my contribution on the final schematic. I think this circuit deserves a snazzy schematic.
Old 28th January 2013, 04:52 PM   #126
dadod's Avatar
Kean did you notice this Current conveyor as a voltage amplifier
Old 28th January 2013, 05:57 PM   #127
keantoken's Avatar
Well, that's why I made my suggestion. In the schematic in post 117 you could add my name next to yours. In any case, the idea was yours and you are doing the testing. I helped refine the design.
Not meaning to demean, I just really like this circuit. It deserves good documentation.
Old 28th January 2013, 08:24 PM   #128
dadod's Avatar
OK here it is.
File Type: txt BOM-GainWire-300.txt (802 Bytes, 32 views)
Old 29th January 2013, 08:15 PM   #129
dadod's Avatar
Here is what I think to use for shunt regulator to power GainWire. I don’t have spice models for IRF610/9610 mosfet so I used what was close enough just to simulate it. Input voltage is +-42V because I have such transformer. I like to use quite simple circuit to get good shunt regulator. This one is similar to the Borbely simple shunt reg, just I did not want to use zener diode, so here is CCS + resistor instead. I am not sure that 1.3V is enough to get JFET CCS to work properly, but some use just 0.65V. I simulated one more complex circuit and did not get significantly better result.
dado
Old 29th January 2013, 09:13 PM   #130
keantoken's Avatar
Can you show output impedance?
I like this design. However the bases of Q10 and Q12 see an impedance of 10k. It's like having 10k base stoppers. You may try bypassing R3 and R12. Even something as small as 10p may work well. I have not actually studied it however.
IIRC Salas made a DN2540 model, and I'm guessing that is what you should use. I'm no expert on shuntregs like this, but if you can make sure it's stable then the circuit looks great to me.
Current conveyor as a voltage amplifierHide this!Advertise here!
High voltage, low current output stage for class D amplifier ionomolo Class D 46 30th December 2017 11:35 PM
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 09:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 06:12 PM
voltage vs current Raj1 Solid State 1 12th June 2004 05:35 AM
