Current conveyor as a voltage amplifier
Old 7th January 2013, 08:08 PM   #101
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by keantoken View Post
Maybe true for modular instrumentation amplifiers but this circuit will only be connected one way in one circuit. It has passed all the requirements so far so even if CMRR is low, there may be little to gain from increasing it with this particular implementation.
R7/R8 give the + input slightly extra gain. At a current gain of 18.54k at the Jfet sources, this calculates to a CMRR of 2.85db, which seems to agree with the simulation. R7/R8 need to be bootstrapped to the negative input or replaced with current sources.
I think in the first simulation since you bypassed the 1k resistor you caused major offset which saturated/clipped the output resulting in optimistic PSRR.
I was thinking of both, CCS and bootstraping when I started this lineamp, but do I need all that complication? I am preparing PCBs and after listening to it I will deside upon implementing some of those upgrades.
Thanks Kean I like how you prceive all that electronic staff, realy remarkable.
Damir
Old 7th January 2013, 08:40 PM   #102
keantoken is offline keantoken  United States
keantoken's Avatar
Only for the purposes of CMRR measurement do you need the CCS. R7/R8 act like a 11k resistor parallel to R9, so they are relatively benign except for noise conducted from the rails. However if your rails are well filtered with low impedance I don't think this is a problem. How much current is going through your BC5xx C-multipliers? BTW, 4.7k/470k for the C-multipliers seems pretty reasonable.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 7th January 2013, 08:56 PM   #103
dadod's Avatar
C-multiplier disipation is les then 80 mW(65mA) and it is 47k/470k.
Attached is similar lineamp but with GNFB and sub ppm distortion. It will be easy to transform non GNFB one to the GNFB one, but I am not sure do I need that.
Old 7th January 2013, 09:08 PM   #104
keantoken's Avatar
The circuit without NFB is very inert. Potential reactive areas are the output CFP and Baxandall cascodes. They may need a small cap at their collectors or something else if they oscillate.
In any case, I've found inert circuits tend to have the most realistic imaging. The more positive and negative feedback paths, the more potential for adverse resonances and poor RFI tolerance.
It seems like a simple enough modification, maybe you can try it with an without feedback? You would have to bother with checking and compensating for stability though.
Old 8th January 2013, 10:19 AM   #105
dadod's Avatar
The same distortion as GNFB citcuit I've got with CCS and bootstrap, but with the cost of four more transistors and four CCS(mosfet).
Old 8th January 2013, 02:31 PM   #106
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
I`m working on something similar. What`s the nose level of input stage?
Svakog dana u svakom pogledu sve manje nazadujem.
Old 8th January 2013, 03:25 PM   #107
dadod's Avatar
Noise is directly proportional to the R1 value, lover R1 lover noise, but higher distortion.
After the listening test I will decide what metters more, noise or distortion.
Attached two noise simulation.
dado
Old 8th January 2013, 05:27 PM   #108
thanks!
Old 9th January 2013, 12:11 PM   #109
dadod's Avatar
CMRR for Gainwire with CCS and bootstrap is here.
Old 9th January 2013, 07:24 PM   #110
keantoken's Avatar
I'll bet you could replace M1 and M2 with resistors without losing anything. Q17/18 will not improve PSRR, and bias loading here is relatively benign.
Current conveyor as a voltage amplifierHide this!Advertise here!
High voltage, low current output stage for class D amplifier ionomolo Class D 46 30th December 2017 11:35 PM
The InSense Current Conveyor bcarso Digital Source 17 20th August 2012 09:11 AM
An inverting current conveyor approach bcarso Digital Source 0 30th July 2012 06:12 PM
voltage vs current Raj1 Solid State 1 12th June 2004 05:35 AM
