Active crossover component suggestions?
Old 17th November 2012, 04:00 AM   #1
Beer30 is offline Beer30  United States
Default Active crossover component suggestions?
I'm thinking of taking a double dip into bi-amping and active crossover design!
I'm looking for suggestions on the active components that are:
- relatively forgiving
- of reasonable quality
- inexpensive (good value per US$ given the above considerations)
If such a beast exists. Opamp, transistors or some flavor of FET, I'm open to suggestions.
Right now I've got a chip amp with some full range speakers that I'm quite happy with. I'm thinking of throwing together a sub for the above mentioned setup.
I'm looking to get my hands dirty. If it actually works, bonus!
Here is my plan: Active Filters
Anyone have a favorite?
Old 18th November 2012, 07:02 AM   #2
andyr is offline andyr  Australia
Your link was to SL's site. You might like also to look at Rod Elliott's site "ESP", here: Elliott Sound Products - The Audio Pages (Main Index)
Go into "Projects" and look at P09 and P81. I use these in my 3-way active Maggie setup.
Re. what actual components to use - that's entirely a matter of how much you want to spend. My own are built with Beyschlag metal film resistors but the electros are Black Gate and the film caps are RelCaps. I used AD826 opamps - simply bcoz I read about 10 years ago that these gave good bass (in a comparison with others).
BTW, IMO Siegfried's design are complex - Rod's much simpler. Which is the better one for you depends on what style of speaker you are turning active. In my case, Magiies just need simple HP/LP filters - so Rod's circuit is ideal.
Good luck,
Andy
Old 18th November 2012, 08:07 AM   #3
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
If you are just going to go with a sallen-key 2nd or 4th order then you won't need any large value caps, I've used vishay MKP-1837 caps in my prototype active crossover. They are good quality, suitable for this type of circuit and their tolerance is very good.
I went with a mixture of vishay dale cmf55, cmf60 and welwyn 0.1% resistors (as local suppliers don't stock all values in any particular series), which is probably overkill but I wanted to make sure that there were no channel to channel differences.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 18th November 2012, 08:37 AM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
My best advice is to buy many more passives than you need, then just match yourself. Consistency between stages and across channels is much more important than exact matches to nominal values that simulators pump out.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 19th November 2012, 07:33 PM   #5
Itsmee is offline Itsmee  England
Itsmee's Avatar
I like Rod Elliot's 2 way 24dB Linkwitz Riley project.
Linkwitz-Riley Electronic Crossover
But personally I don't like opamps, instead I would use Nelson Pass style B1 buffers.
B1 Active Crossover
I'm toying with the idea of using a cascoded version of the buffer used in the F4, that way I can get a large voltage swing straight into a BA2 output stage, that way I only need one gain stage before the crossover, rather than one stage each for the low and high sections.
Active crossover component suggestions?Hide this!Advertise here!
Active crossover freq for TLK TL6 - suggestions? aspringv Multi-Way 2 10th January 2012 09:36 AM
XO3: The 1/2/3-way Active Crossover/filter PCB. Design suggestions welcome! s3tup Analog Line Level 52 5th October 2011 03:27 PM
Active Digital Loudspeaker Crossover - Part Suggestions solicitation speakerguy79 Digital Line Level 0 2nd December 2009 04:26 PM
<AUS> B3S active crossover design - Value woofer suggestions? TheSeekerr Multi-Way 0 25th August 2008 12:46 PM
Component Suggestion: 2-way active now, 3-way active later CanadianDream Multi-Way 6 3rd August 2007 04:53 AM
