Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th November 2012, 01:43 PM   #21
freax is offline freax  Australia
Owner and operator of irc.tenettenba.info
freax's Avatar
Originally Posted by freax View Post
And it would have to be 1 channel per fiber optic cable.
And it would have to be 2 channels of fiber optic cable to represent the - and + aspects of a pure sinewave signal, so for stereo you would need 4x fiber optic cables (which these days isn't that hard, nor expensive to buy.)
Rather...
Old 12th November 2012, 01:54 PM   #22
DF96 is offline DF96  England
AM would be worse. No need for brainstorming. The idea is daft, as I said earlier in this thread. It is one of those ideas which fits the following criterion: anyone who knows enough to make a realistic attempt at doing it, knows enough to know that it won't work so no point in trying.
I suggest you go away and design, build and test a wideband FM receiver which meets or exceeds the current state of the art. Then you will have some idea of the difficulties in scaling performance up to interconnect standards. I have designed an FM receiver, which used the best chips available at the time, but it is nowhere near the bandwidth or dynamic range of a simple piece of wire.
Old 12th November 2012, 09:57 PM   #23
dmills is offline dmills  United Kingdom
Lots of noise on the output of a typical cheap laser diode, especially when you start to vary the current (They usually mode hop if you even look at them funny) and are seldom single longitudinal mode across any sane modulation range, that is before we get into what happens as the die heats and cools. Most lasers are also seriously non linear in their output power as a function of diode current, and often have a smallish range between threshold and excess current causing the optical power density in the cavity to blow its front mirror off (Yes, really a common cause of LD diode failure).
Trying to maintain low noise single longitudinal mode operation gets you into tricky exotica like ECDLs and ring lasers, with a standard diode laser you are doing very well to get a 1M coherence length!
Besides, why on earth would you want a laser for this? LEDS are cheaper and it is not like you are trying to couple to a single mode fibre for a long haul link.
Why this fascination with one channel fer fibre, ever hear of prisims, there is more then one wavelength of IR you know.
Still seems to me that simple twisted pair with good drivers and recevers stomps all over fibre for a short analogue run like this at the sorts of nearly zero bandwidths needed for audio (All audio is as near to DC as makes very little difference!).....
Regards, Dan.
Old 13th November 2012, 12:34 AM   #24
freax's Avatar
Ok, thanks guys, thats what I really wanted to hear to see if it was viable or not. and at the current state of tech and for the forseeable future it isn't.
Old 13th November 2012, 01:57 AM   #25
Hi
I talked with a friend of mine yesterday about what we are trying to do. He said that he had unusually good results using a V/f converter for a limited bandwidth. He suggested using a Burr-Brown/TI chip called a VFC110. He also said that using it beyond 2MHz is a loosing battle. Yes I know we will probably blast the 160m - 1.8 to 2MHz Amateur band, but so be it. My HI-FI is more important than 200kHz of amateur radio. Besides by shielding and paying attention to circuit details we should not transmit much more than 100uW or less.
I will have to study the chip specs more carefully, to see if we can get that to work.
Still we would have to put this thing inside a local precision feedback loop to make it work to our enhanced spec.
Using this approach we would transmit the frequency over the fiber optic link, maybe using different IR wavelengths for several channels. I am in favor of using the standard "Toslink" connector and their transmitter and receiver just to stay within reasonable expense-bounds.
On the receiving end we should use the identical f/V converter as used on the transmit side. I do not yet know if the VFC110 can be used as a f/V converter as well, but knowing B-B my guess is that by "pulling some pin sideways" you can.
Back to my paper on the History of Computer Assisted Tomographic (CAT) Image generation, due on Friday.
Later-
Hans J Weedon.
Old 13th November 2012, 10:16 AM   #26
You want to introduce crossover distortion into an interconnect?
I suggested you try to build an FM tuner, to learn about the snags. Maybe you should build a push-pull amplifier too?
I think you may find that the law disagrees. Domestic items using these frequency ranges are usually required to include nulls in emission at amateur band frequencies.
Old 13th November 2012, 12:13 PM   #27
Hi I may not just find it I know it.
Regarding RFI, the basic spec is not to radiate more than 1uV/m at a 3m distance. There are lots of concessions in the spec to yield to lobbyists, but that is the basic class B spec. What this really means is that if you take ordinary care in assembly, and round off edges on digital timing signals the spec will in general be met. "Sky-wiring" will be suspect, but laid out on a multilayer PC board it is more probable that you will be quiet enough.
Hans J Weedon.
Old 13th November 2012, 12:41 PM   #28
freax's Avatar
It is possible that a tube (ex, preamp tube) could be modulated by this project.
Take care and keep a frequency counter next to the desk to you turned on at all times, maybe a radio too.
Old 20th November 2012, 11:51 PM   #29
Hi Guys.
I "cheated" I did an on-line purchase of a Stereo-RCA connector input to Toslink optical A/D converter output and a complement Toslink to RCA stereo D/A converter output. I plan to measure the pairs frequency response, signal to noise ratio and distortion over the next few weeks. It is perhaps a little too much "consumerism" for you guys to do it that way but only if the signal is "junk" will I not use the pair. It will set me back perhaps as much as US$75 plus maybe 4 hours of testing. I have the appropriate test equipment in my Audio Lab (Ha Ha) downstairs I think.---- A Krohn-Hite low distortion sine generator and an "old" repaired HP distortion analyzer. I do prefer my Heath-Kit sine oscillator and the Heath-Kit Distortion analyzer though, because I put them together myself. Who can hear 0.03% distortion anyway. I will write a comprehensive report with nice curves (I think)
Wish me luck, the equipment arrives in about 3 days, but we have Thanksgiving in the way.
Hans J Weedon.
Old 2nd December 2012, 11:19 AM   #30
freax's Avatar
Any luck on your idea? I might be a good idea to simply use a high quality A/D & D/A combination but I feel that you shouldn't have to.
Have you considered using quad shield as a substitute for the shielding problems that you are having? Maybe even earthing only one end of the cable?
Here is my thread on the BNC + Quad Shield combination:
Are there many people using BNC out there? or RG6 Quad Shield?
Quad might do the trick, you never know.
line to optical ---> optical to analog dirtbiker1824 Digital Line Level 5 27th February 2011 03:29 AM
Optical in vs analog in via Ext Decoder input lectrolux Chip Amps 0 25th January 2011 10:15 AM
converting optical to rca analog kazoo Digital Source 8 22nd March 2007 05:24 PM
Optical/Coax to analog? soundNERD Digital Source 2 29th September 2003 03:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
