Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th November 2012, 11:17 AM   #11
say you have 5inputs, not that uncommon and you are on position 2 at the moment.
How many presses to hit position 5? then position 4?
Not at all convenient.
Old 7th November 2012, 10:23 PM   #12
DUG is offline DUG  Canada
Switch centre off is input A
one side energizes K1 for input B
the other side energizes K2 for input C
K1 right and K1 left can be a dpdt relay or two spdt
same with K2
Does everyone forget the normally closed contacts?
Doug We are all learning...we can all help
Old 8th November 2012, 12:15 AM   #13
sofaspud's Avatar
A 2P3T slide switch is fairly easy to find.
The 2 poles are connected on the preamp side; the 3 throws are the different inputs.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 8th November 2012, 01:07 AM   #14
2P3T slide is a neat solution! I wonder how I can shoehorn that neatly into/onto 1/16" aluminum plate?
Old 8th November 2012, 02:53 AM   #15
sofaspud's Avatar
It should come with mounting hardware: machine screws or little nuts & bolts. The downside is it will probably take up a little more space on the backside than a toggle or rotary due to its length.
Old 10th November 2012, 01:21 AM   #16
Hey,
This switch works well and is pretty small.
M2044SS1W01-RO NKK Switches | Mouser
to wire it up, follow the diagram below.
dave
need high-amp DPDT toggle switch for speakers cyclecamper Subwoofers 16 9th April 2012 04:06 PM
Request for wiring help - toggle switch and cap involved kach22i Multi-Way 9 28th December 2011 02:07 AM
Wiring a DPDT for direct in & 2-100k mono pots ..? JandG Tubes / Valves 2 5th December 2009 03:51 AM
toggle switch for input selector audio_moksha Tubes / Valves 25 14th November 2008 07:29 PM
Need help wiring DPDT switch Static1 Parts 4 14th October 2003 10:25 PM
Copyright ©1999-2013 diyAudio
