Signal booster for cd player
Old 28th October 2012, 09:38 PM   #1
raresvintea is offline raresvintea  Romania
Default Signal booster for cd player
Hello, i have installed in my car an amplifier Helix H400 and a player. On the max volume (35/35) with 1kHz teste tone the output has 4V. But when i play music i could not reach 23/35 because i have a lot of distorsions coming from player. In this case i want to make a preamplifier, to rise the voltage from 2V on 23/35, to a 8V rms.I have +/-15V power suplly and i want an ideea or a good schematic, for example with NE5532 or something like that.
Can you help me? "
Old 29th October 2012, 09:19 AM   #2
R.I.P.
no.
regards Andrew T.
Old 29th October 2012, 12:17 PM   #3
that answer makes you feel better?
Old 31st October 2012, 05:36 PM   #4
freax is offline freax
freax's Avatar
cure the reason for the distortion coming from your player first (head unit), its probably a cheap DAC inside of that head unit, and the only way to cure that is by replacing the head unit altogether with another source.
Simply raising the line level voltage from 4vRMS to 8vRMS won't cure your problem and will infact just make things worse imho.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 31st October 2012, 05:46 PM   #5
R.I.P.
Turn up the input sensitivity of your power amplifier.
No way do you need a line level booster.
rgds, sreten.
Old 8th December 2012, 08:49 PM   #6
I think i know what i want, because i measured the voltage on my player with 1kHz test tone, and on 20/35 volume it has only 1-1.5V, on 35/35 where the sound it's distorsonated, i get 4V output, but useless.
In this case i want to try. If you can't help me please don't make offtopic!!!!
Old 10th December 2012, 02:33 AM   #7
Chris Daly is offline Chris Daly  Australia
Can you help me? "
Hi raresvintea
You need to cure distortion first, it is likely you have a mismatch with level coming out of your player to then interface with the Helix H400. The Helix Manual here: http://www.products2006.audiotec-fis...h/pdf/h400.pdf
states 600mv to 8v which suggests that the Helix amp has circuitry that attempts to match this enormous range of input - then again it could be a misleading misprint... as it unusual not to have a fixed input level. Input impedance is 10k
Using the players ( brand? model ? ) variable pre amp out connection it should deliver adequate level to your Helix 400, check your connection that you are wiring the variable out from the player to the helix 400. this is usually wired with a stereo RCA signal lead.
Further answer may be provided by using a level matching circuit such as a suitably rated L pad attenuator, but this would be unusual for car audio which is designed to be plug and play, with little need for other circuitry.
Cheers / Chris
Signal booster for cd playerHide this!Advertise here!
"A standard CD player outputs signal at 24V" wwenze Digital Source 16 13th July 2009 04:50 PM
take digital signal from cd player tralala Digital Line Level 9 26th March 2009 06:31 AM
How can I convert SPDIF to EFM (RF) signal, to use a cd player as a DAC ? gaetan8888 Digital Line Level 10 8th February 2009 07:32 AM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
