Current noise between DC coupled op amps?
Old 24th October 2012, 05:59 PM   #1
miallen is offline miallen  United States
Default Current noise between DC coupled op amps?
Does DC coupling op amp stages add current noise?
I have a line-level input consisting of a very simple non-inverted unity gain op amp stage followed by an inverting op amp stage with it's inverting input connected to the wiper of a pot to control the input level. The op amps are NE5532 which of course have a little bit more offset than most so I'm wondering if I need to be concerned about current flowing between the two stages.
So my question is - what would yield better noise performance:
a) leave out a coupling cap so that I can use small resistors with the inverting op amp stage or
b) use a coupling cap to eliminate any current flowing between stages and use larger resistors sufficient to get low frequencies
Note: The input op amp is located 8 inches away from the level control.
Any advice would be appreciated.
Mike
Old 24th October 2012, 09:41 PM   #2
DF96 is offline DF96  England
Keep DC currents away from volume pots, if you want low noise.
Old 25th October 2012, 04:45 AM   #3
I think I'm going to use the baxandall active gain stage circuit on page 237 of Small Signal Audio Design by Douglas Self. That section makes it pretty clear that coupling caps are important when using bipolar op amps.
Current noise between DC coupled op amps?Hide this!Advertise here!
DC coupled Sand 'n Glass with Current Feedback ChocoHolic Tubes / Valves 35 31st March 2012 12:16 PM
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 11:50 PM
CF op-amps and DC servo? theAnonymous1 Chip Amps 2 15th August 2010 12:35 AM
Pitfalls to warmup delay in DC coupled multiple railed amps? leadbelly Tubes / Valves 3 20th March 2009 08:29 AM
Opamp that can be dc coupled ? beppe61 Solid State 37 20th January 2008 09:21 AM
Copyright ©1999-2017 diyAudio
