compact stackable relay attenuator - something new
Old 21st October 2012, 05:53 PM   #1
Earfanatic is offline Earfanatic  Hungary
Default compact stackable relay attenuator - something new
There are many options when a DIY-er want volume control. Some of them are regular and some are very high-end. High-end options usually prevent the audio signal from going trough a potentiometer and uses fixed steps with more precise matching between channels.
What I show you is not entirely new, it is a relay based stepped attenuator.
Stepped attenuators can be very-very precise and can replace old potentiometers. In a regular stepped attenuator there are like 24-26 steps. This is why the relay based stepped attenuator is made, which can do easily 4x the steps, or more.
My idea was to design such an attenuator for my DIY projects but something hit my mind. Many of us likes the ODAC the USB DAC designed by NwAvGuy. When I first got my hand on it I was amazed how small it is. And it got me to think if I can do a layout for my attenuator in such a small form factor.
For this I had to use a 2 board stack design. But not only 2 boards are possible. The way I show You next is possible to have:
Single ended setup (most stereo setup)
Balanced setup (like some headphone amplifiers)
Multi-channel setup (home cinema)
To complete the specs.:
It supports 128 logarithmic steps, it has 2 channel input with source selector, remote control receiver and an external delayed relay drive (possible headphone pop protection).
Size: 58mm x 50mm x (stack high)
I have a working prototype on my desk, it sounds excellent. I will make a few more.
Next to do:
-buying long leg stackable female headers
-fine tuning layout
-taking more photos
Old 22nd October 2012, 04:58 PM   #2
How do You guys like it?
Are there any live multi channel DIY projects I can check on?
Old 22nd October 2012, 08:01 PM   #3
I have to correct myself as there was some misunderstanding on a different forum. The attenuator was made in sight of a company for an ODAC. Thus it was first planned only single ended, as the ODAC.
My plan was to build a small box, and a desktop amplifier with USB DAC, this way, the attenuator could be mounted below an ODAC to occupy the least space in the box.
Only in the design process it turned out it could be expanded to balanced or even multichannel (for an appropriate source).
compact stackable relay attenuator - something newHide this!Advertise here!
Yet another relay attenuator jwb Solid State 34 21st July 2010 08:17 AM
YET another relay attenuator question robmil Solid State 0 14th April 2008 06:44 AM
Relay Attenuator for tube amp Vidi Tubes / Valves 9 11th December 2006 05:09 PM
relay based attenuator squadra Solid State 21 1st December 2004 11:10 PM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 12:00 PM
Copyright ©1999-2017 diyAudio
