Tube preamp kit from ebay - worth my time? - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th October 2012, 11:54 PM   #31
kevinkr's Avatar
I enjoyed the year and a bit I spent in Tel Aviv as a kid, very friendly and to me at the time, exotic place. Hope it has not changed too much, must be much bigger.. Went to school in Jaffa..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st October 2012, 03:45 AM   #32
Bigun is offline Bigun  Canada
Bigun's Avatar
Nice place Jaffa, it's been awhile though.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 21st October 2012, 03:35 PM   #33
kevinkr's Avatar
I assume by this point that Jaffa has pretty much been overwhelmed by Tel Aviv. There was a very cool Arabic restaurant and bar on a cliff overlooking the Mediterranean with a patio having spectacular views. I still remember the hookah smoking patrons in the bar area which was upholstered in some red velvet.. Food and soda was good..
Old 3rd October 2015, 07:30 AM   #34
Send a message via Yahoo to Francis Jansz
Default MATISE TUBE FANTASY PRE AMP.
Originally Posted by Tankpopper View Post
so i have alot of options on the table right now.. im gonna give everything a look and make my choice. im still considering the ebay kit option as it is very cheap and this project is intended for fun and i want to keep it as simple as possible! heres another kit i saw on the bay:
6Z5P 6N8P Tube Preamp Board with Volume Bass Treble Adjustable | eBay
this one seems a bit nicer then the first one i posted.. no balance which is good and the tubes are standing so better heat management. as far as the circuit goes - i think its pretty much the same.
Old 3rd October 2015, 07:40 AM   #35
Hi I just purchased a MATISE HAND BUILT PRE AMP it uses 2 X ECC83 and 2 XECC81 and 1 XEZ80 Mullard Rectifier tube, I have not plugged it in as yet, As I just ordered a set of Tubes and waiting on Delivery, This PRe AMP has Got 2 Pairs of RCA OUTs and 2 Pairs of RCA Inputs and is wired to for AC240 VOLTS.
ANY Idea how does this pre amp sounds, I will be Coupling it to a SOLID State Class A CROWN POWER LINE 3 Power AMP, as a Friend of mine is Building a Pair Of TUBE MONO BLOCKS using 2 X Driver Tubes and 4 X KT 88 Output Power tubes. I got a Pair of KLIPSH LASCALA 3 way Speakers,
Any idea how this pre amp will match my speakers.
Kind Rgds
Francis Jansz
fsj@iprimus.com.au
Old 3rd October 2015, 07:55 AM   #36
Default 2 or 3 Way Tube Variable Crossover Unit
I am thinking of By Amping or Try amping,
I am seeking for a TUBE CROSSOVER UNIT either 2 way or 3 way Stereo.
Any idea of what they cost, Or has any one got a Good Circuit Diagram so i Can Get a Friend to Build it for me.
The 3 way Speakers I got is: (1) Bass Woofer KLIPSCHORN K33 Works at 4 Ohms,
MID BASS MIDRANGE HORNS JBL 2386 B /8 ) ohms , From 500 Hz to 5000 Khz at 12 DB Slope, With JBL 2" Driver, The Tweeter Can work down to 3,500 Khz, I am thinking of Crossing it at 18 DB Slope 8 Ohms from 5000 Khz or 6000 Khz It is a JBL SUPER BULLET 2402 Tweeter.
Any help or advise Will be Appreciated.
Kind Regards
Francis Jansz (fsj@iprimus.com.au)
Old 23rd December 2015, 02:05 PM   #37
jan.didden's Avatar
In case anybody is still interested: this appears to be the schematic.
Doesn't look half bad I think.
Jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
IFI 6SN7 X3 (6N8P-6H8C) Tube Valve Preamp Kit Board from eBay davidhugo Tubes / Valves 1 13th February 2011 12:15 PM
ebay, 7c kit, worth it? trigger Tubes / Valves 21 8th January 2010 01:38 PM
Ebay Tube Preamp Kit bcrescen Tubes / Valves 10 2nd February 2008 12:33 PM
Copyright 1999-2017 diyAudio
