Differential Line Driver - Impedance Questions
Old 26th October 2012, 08:20 AM   #21
R.I.P.
Now I understand.
Jung also uses the bridge analogy and probably predates Whitlock.
regards Andrew T.
Old 28th October 2012, 06:21 AM   #22
rcw666 is offline rcw666
I would have thought connecting a 5532 or 833 like this is about as good as anything.
rcw
Old 28th October 2012, 08:38 PM   #23
dmills is offline dmills  United Kingdom
It needs line buildout resistors in series with the outputs, and they need to be fairly precisely matched. Somewhere in the 50 to 100 ohm region is usually ok.
This however is in most ways overkill, you can leave the lower section out and just connect output - to circuit 0V reference via a build out resistor and get almost all the benefit.
If is also usually better to make opamp buffers inverting as this usually gives lower distortion then the non inverting configuration due to the lack of common mode voltage swing at the opamp inputs.
Also it needs protection from P48 and some RFI protection (Common mode choke or something).
Regards, Dan.
Old 28th October 2012, 10:53 PM   #24
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
There is one difference between both polarities driven and one polarity undriven ("impedance balanced") outputs - with both polarities driven, signal coupled _out_ of the stage to another nearby is minimized.
This is rarely important for home audio, but matters for snakes or other multi-channel constructions.
Thanks,
Chris
Old 28th October 2012, 11:01 PM   #25
Depends, the coupling in that case is capacitive (The current in the two legs is substantially equal and opposite if the input stage is competent, the input common mode impedance to ground being large in any well designed stage), and audio frequency capacitive coupling is about the worlds easiest thing to screen.
Now I will grant that the two opamp driver returns the current on the other leg to a supply rail rather then the circuit reference plane, but with competent design that is pretty much an implementation detail.
Regards, Dan.
Differential Line Driver - Impedance QuestionsHide this!Advertise here!
Looking for a 5V highspeed differential driver for SPDIF output wotan Digital Source 0 26th January 2012 08:32 PM
Differential pair questions diy didi Solid State 11 1st January 2012 10:38 AM
Help on CCS PP differential driver stage for SE 845 amp swordsman Tubes / Valves 4 21st April 2008 08:22 AM
A high voltage drive fully differential driver/op amp Russ White Pass Labs 21 18th July 2007 10:14 PM
Suitable operating point for 6SN7 as a differential driver ? ray_moth Tubes / Valves 15 27th October 2004 08:50 AM
