Go Back   Home > Forums > Source & Line > Analog Line Level
Old 16th October 2012, 03:35 PM   #1
kp93300 is offline kp93300  Malaysia
Default opa 2889 buffer circuit
Hi
I need some advice
See the schematic attached . This is from the datasheet of the opa2889.
The link for the datasheet is
http://www.ti.com/lit/ds/symlink/opa2889.pdf
I wish to use this op amp as buffer after a dac and before the amp. .
What does the label of V0 -DIS imply ?
If I want unity gain ,do i short R3?
much appreciated .
kp93300
Old 16th October 2012, 04:11 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Leaving this disable pin open, or holding it HIGH, operates the OPA2889 normally. If pulled LOW, the OPA2889 supply current drops to less than 20μA/ch while the output goes into a high-impedance state.
You didn't read the datasheet, first page?
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 17th October 2012, 12:45 AM   #3
Hi peranders
thanks for the info.
I read but i do not understand !
I am thinking of buying a few to play with it.
thanks
kp93300
Old 17th October 2012, 05:23 AM   #4
peranders's Avatar
What is means is if you let this pin be unconnected, the opamp will work as expected. If you ground this pin the opamp will be shut off and also the output stage. In your case I'll suppose you should forget this pin.
Old 17th October 2012, 11:06 AM   #5
AndrewT is online now AndrewT  Scotland
Originally Posted by kp93300 View Post
........... I want unity gain ,do i short R3?...............
What does the datasheet say?
That may be a clue to whether it can be used as a buffer.
Old 17th October 2012, 01:38 PM   #6
Hi
thanks peranders and Andrew
The datasheet says it is unity gain stable,
I quote from the datasheet
1FEATURES
2• FLEXIBLE SUPPLY RANGE:
+2.6V to +12V Single Supply
± 1.3V to ± 6V Dual Supplies
• UNITY-GAIN STABLE
• WIDEBAND ± 5V OPERATION: 60MHz
(G = +2V/V)
• OUTPUT VOLTAGE SWING: ± 4V
• HIGH SLEW RATE: 250V/ µ s
• LOW QUIESCENT CURRENT: 460 µ A/ch
• LOW DISABLE CURRENT: 18 µ A/ch
thanks
kp93300
FS: opa 2134ua, opa 134ua, opa 2604ua supernet Swap Meet 0 19th August 2011 03:54 PM
FS: Audio-gd OPA Moon Dual Opa gabanyayaya Swap Meet 1 28th May 2010 06:14 PM
OPA-Earth & OPA-Sun, Discrete Opamp diy kits lineup Solid State 38 25th February 2009 05:40 PM
What's the different between OPA-541AM, OPA-541AP and OPA-549T 100db Chip Amps 1 7th September 2006 03:26 AM
Amp Circuit of Opa+Mosfet/normal transistors. Dj BASS AMP Solid State 1 23rd May 2004 05:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
