Help needed with diy outpout switcher relay based - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th October 2012, 09:49 AM   #1
pieca is offline pieca  France
Default Help needed with diy outpout switcher relay based
I'm currently trying to create a latched relay based balanced output switcher.
For each stereo output, I'd like to use 2 DPDT latching relay
I'm considering OMRON G6-JV-2P-Y
I want to trig them via a push switch, but I need a Led as a visual feedback of their states (on/Off)
So I need a one shot pulse generator circuit.
I've found a lot off off theses circuits based on 555, or CD4013, but none of them are able to give me a visual feedback of their state via a led…
Non latching circuits are easier to implement with a led, but I'm not sure they'll be great for audio works
Is anyone could help me?
Old 15th October 2012, 10:13 AM   #2
Johno is offline Johno  Australia
Johno's Avatar
Hi Pieca,
A simple solution is to use a push switch or transistor or scr to turn the relay on. Then use one of the sets of contacts across the switch/transistor/scr to conduct all of the relay coil current - thus holding the relay on until power is switched off.
Very useful with delay circuits, eg for power supply soft start or speaker delay switching.
Cheers John
Old 15th October 2012, 10:25 AM   #3
There are a few ways, wire a LED using say 15ma choosing a suitable resistor feeding its anode , and its Cathode to Ground to illuminate when the coil receives voltage.
You could also wire a LED in series with the coil, ie positive supply to Anode through the LED to its cathode, to + of the relay, however expect a voltage drop of 1.7 volts for Red ,and 3v for White, this voltage drop may or may not be what you need. In this method the coil resistance serves as a resistor - so suits relays with higher coil resistance - substituting the usually used dropping resistor. -
Cheers / Chris
Old 19th October 2012, 12:16 PM   #4
Thanks for your help.
I've manage to use latching relays which is a far more simple design :
latching switch, led, relay, diode and that's all…
Working great!
Relay audio switcher raidfibre Analog Line Level 2 6th September 2012 12:27 PM
My DIY Pre amp switcher pops! MuthaFunk Parts 5 6th May 2009 02:07 PM
Relay based source selector. Help needed! MASantos Chip Amps 9 8th August 2007 11:28 PM
relay based attenuator squadra Solid State 21 1st December 2004 10:10 PM
Relay-based passive volume control project BrianGT Everything Else 110 1st March 2003 01:27 AM
Copyright ©1999-2017 diyAudio
