| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hey everybody. I'm new to this forum and am loving the DIY audio hobby. I've almost completed a classdaudio sds1000 amp for my Cleawave Loudspeaker design Dynamic 4tse speakers I already built and love. I am interested in building possibly a high end preamp or dac. I am currently using a denon avr3311 for music and home theater and wondering what other things I can build to increase the sound quality. i love the sound already, so it is partially just for the fun of the project, but would like some direction. Possibly a kit or existing design? Thanks in advance!
#2 |
Forgive me..I should add that I use a Squeezebox touch for a source 99% of the time. Can either be connected by rca or optical connector
#3 |
Would you just be looking for 2ch preamp?
#4 |
Sorry, should have gave more detail. I want to keep using the denon for movies. I guess 2.1 channel because I have an extravagant underfloor IB subwoofer system. I do also have a mini dsp8x8 for eq ing both sub and towers if needed. Thanks.
#5 |
I'm not really sure that what I am wanting is possible with having 2.1 in an audiophile quality diy preamp, so I may not know what I am talking about. Hence, why I am seeking advice hear
#6 |
The volume control is normally the very last item before the Power Amplifier.
If you have an integrated 2.1 amp + decoder you don't have access to the three inputs into the three power amplifiers. If there is a way to break into the feeds into the power amplifiers, then you would need a three channel pre-amp to control volume. |
#7 |
I have two seperate amps. One four the tower speakers and another for the subwoofer system, if thats what you are getting at. Thanks
#8 |
Soakin' up the Sound!
If you're looking for something to answer the DIY bug, try Googling "DIY 2.1 amplifier." There are many high quality kits available. I don't know much about DSPs, but can your DSP provide a 2.1 configuration if you use a typical two channel signal? If so, there are many high quality two channel amps available. I built a chip amp from Audiosector and really like it a lot. Tube amps are another option. I rebuilt a tube amp out of an old console.
Mike
Marantz PM8003 amp, Squeezebox Touch, DIY Krystals Jolida SJ502B, Mark Audio Alpair 10.2s
#9 |
Thanks, I already have the amplifiers, I am just wondering about a preamp. When I google preamp kits, it looks like they are just a board, and looks like I would need to figure everything out that doesn't come with it. which isnt a problem if I have proper instruction. I don't know if the increase in sound quality over my denon avr would be worth it, but if the kit is relatively inexpensive I would like to try. would learn a lot in the process I'm sure.
#10 | |
I have a PCBs for this preamp DIY Simple Active Preamp - AudioKarma.org Home Audio Stereo Discussion Forums very easy to build even for the first timers.I can send you the part list(only 13 parts).This can be run on 2x 9 V batteries.Total build cost should not be more than $30 and a case of your choice.This will definitely improve performance of your AVR Regards, Sachin |
| newb looking for preamp design and a few questions answered | lefthandRED | Analog Line Level | 3 | 4th January 2011 01:09 PM |
| Newb DIY DAC kit questions | Fasterdamnit | Digital Line Level | 5 | 11th April 2010 06:10 PM |
| Newb Passive Preamp Question | s0rce | Solid State | 1 | 18th November 2006 02:24 PM |
| Does anyone interested PSE STUDIO SL Preamp ? | ANALOG GUY | Solid State | 5 | 19th April 2006 04:00 AM |
