Newb interested in DIY preamp - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th October 2012, 03:31 PM   #11
but a 2.1 system needs a three channel volume control.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th October 2012, 03:37 PM   #12
sachu888's Avatar
Yes you are correct,I should have read that before posting.
Sachin
Old 23rd October 2012, 01:10 PM   #13
I have looked online and have not seen a pre amp kit that is meant to be used with a seperate subwoofer.
Old 25th October 2012, 11:26 AM   #14
Volume control can be two channel and the sub(0.1) can be following these levels after summing.
Gajanan Phadte
Old 25th October 2012, 12:42 PM   #15
Gajanan Phadte
Does that mean I can "split" the signal with my mini-dsp crossover/eq after the pre-amp. Forgive my ignorance.
Old 27th October 2012, 07:44 AM   #16
Hi Keager,
I am also new to this pre-amp DIY stuff. I just started a thread here yesterday and I am trying to do basically the same thing you want to do.
If I understand it correctly, you can in fact "split" or tap the signal after the volume control, to go both to a summing circuit (L+R goes in, and one signal comes out for the subwoofer output) and to the regular amplifier outputs that feed the amplifier that powers your regular speakers.
You can have a look at my thread here: LP/HP crossover for 2.1 DIY preamp?
Although no one has yet replied to my posts
Old 27th October 2012, 03:55 PM   #17
Thanks for the info. I'm quite certain my mini dsp will do all crossover duties just fine. I'm just trying to find a complete pre amp kit now that. Is staright forward and a proven good design. I'm needing the case and all.
newb looking for preamp design and a few questions answered lefthandRED Analog Line Level 3 4th January 2011 01:09 PM
Newb DIY DAC kit questions Fasterdamnit Digital Line Level 5 11th April 2010 06:10 PM
Newb Passive Preamp Question s0rce Solid State 1 18th November 2006 02:24 PM
Does anyone interested PSE STUDIO SL Preamp ? ANALOG GUY Solid State 5 19th April 2006 04:00 AM
Copyright 1999-2017 diyAudio
