Bob Cordell's VinylTrak
Hey!
I built it into a nice box.
I'd be happy to share gerbers and bom with you.
You can send the gerbers to JLCPCB that will be very cheap.
I'm not using it in 'Vinyltrak' mode, just regular RIAA but using the pseudo, open loop, JFET input.
Runs every day on my system.
Let me know.
jb
Will post some pictures.
Hi JB, Very nice job; the pictures look really good.
Cheers
Bob
It is all optionnal : you can bypass it or not.
Same for the diamond buffer: you can have it in the pass or not.
Using configuration switches. You may want to hard wire the configuration you want (these are switches I had in the lab : I don't have a part number fo it).
The assembly drawing (PDF) should make clear how to configure the switches.
Matching transistors is not required: the LSK489 does the important job there itself.
Don't hesitate if you have mre questions,
jb
